Pot Lights - Insulation
Discussion in 'Electrical Forum discussion & Blog' started by coopns, Jul 24, 2009.
  1. coopns
    coopns New Member
    Sep 25, 2006
    Massachusetts
    I have an exsisting fixture going in between 1 and 2 floor. Height is 8 or so inches and insulated. I bought a pot light but it is the non insulated type. Can I simply remove any insulation around that area. Is there a min distance insulation/can distance?
  2. jadnashua
    The installation instructions will state the minimum free air space required around the fixture. It will normally, also be on a sticker on the fixture. You may need to make a dam or box to keep the insulation outside of those dimensions. While similar, each model will be a little different. The alternative is to buy an IC-contact rated version. They are usually not much more, but you may not find that version in a remodel version. This would require you cut then patch the ceiling rather than just cut a hole and insert the lamp.
  4. coopns
    coopns New Member
    Sep 25, 2006
    Massachusetts
    So if I remove any insulatioin anywhere near it...like within a foot, I should be ok. I saw one pot light at the store and it says within 4 inches but I didn't buy that model.
  5. jadnashua
    Every one is different (but similar for similar max wattage). If the insulation is likely to migrate, you may need a dam to ensure it won't get closer than safe. If you just push it back, it could spring back later. If the room above is heated as well, then you could just remove a bunch...it is likely there for noise control.
Similar Threads: Lights Insulation
Electrical Forum discussion & Blog 4 way switch multiple lights Feb 8, 2017
Electrical Forum discussion & Blog Lights won't turn off, sometimes if switch is halfway Aug 24, 2016
Electrical Forum discussion & Blog Wiring lights in series with switch loop at the end Jun 24, 2016
Electrical Forum discussion & Blog 3 recessed lights, switch at end? May 9, 2015
Electrical Forum discussion & Blog Retrofit Recessed lights with LED Dec 3, 2014
