Possible to run off a pressure tank and a timer for two seperate functions?
Discussion in 'Irrigation / Sprinkler Forum' started by bassadict69, Apr 12, 2014.
  1. bassadict69
    bassadict69 Member
    Oct 6, 2010
    ER Registered Nurse
    Benton, La
    I have an irrigation pump with the intake pulling water from the lake. The output of water is tee'd coming off the pump with an 1 1/2 line running up to my yard for a sprinkler (unfinished irrigation system) on one side and a 1/2 inch line coming off the other side of the tee going to a sink and fish cleaning table. Right now, it is all ran by simply flipping the breaker to turn off and on.
    I would love to put a small pressure tank on the small line to use for water to the sink but hope to add some sort of irrigation timer to the irrigation side. Can both of these be done?
  2. valveman
    valveman Moderator Staff Member
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Just use a pressure tank and about a 30/50 pressure switch to control the pump. Then you can add a sprinkler control timer to run one or more electric valves for the irrigation. Just make sure your irrigation zones are large enough to keep the pump running and not let it cycle on and off while using water.
  4. bassadict69
    bassadict69 Member
    Oct 6, 2010
    ER Registered Nurse
    Benton, La
    So come off the main pump discharge to the tank, then tee off downstream from the pump, one to the sink and one to the irrigation line?
  5. bassadict69
    bassadict69 Member
    Oct 6, 2010
    ER Registered Nurse
    Benton, La
    Can I get away with a small tank without the pump cycling like crazy?
Similar Threads: Possible pressure
Irrigation / Sprinkler Forum Possible top connect 2 valves in one zone? Jun 22, 2014
Irrigation / Sprinkler Forum Possible to build my own valve manifolds? Jul 16, 2009
Irrigation / Sprinkler Forum Possible Problems With Rain Sensor Jul 24, 2008
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Wilkins 975xl Flow/Pressure Issues Oct 21, 2016
