Possible flange broken
Discussion in 'Toilet Forum discussions' started by courbro, Jul 23, 2007.
  1. courbro
    courbro New Member
    Jul 23, 2007
    I am planning on tiling my bathroom floor and walls so I decided to be a "good diy-er" and pick up the toilet instead of tiling up to the toilet. Well upon taking up the toilet (where both closet bolts were corroded) I found that the toilet flange did have a cracked part (not major) but I was concerned with what looks like a crack around the inside of the top of the pipe coming from the floor. I want to make sure I can take on what repair is needed but want it done right. Could you tell me if there is a way to repair this without calling in plumbing professionals?
  2. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    If you post a pic we can probably help more...
    As well, do a search on this forum for "closet flange" - a number of threads should offer some help...
  4. jadnashua
    Sounds like the pipe is cast iron. Where is this? cement slab, first floor, second? Do you have access to this from underneath? If you do, you might just want to snap it off and replace with pvc or abs, whichever is more available where you live.
    Ideally, the flange is installed on top of your new tile and anchored through it to the subfloor.
    If that fails, check out repair rings. It will give you something to anchor the toilet to.
  5. courbro
    courbro New Member
    Jul 23, 2007
    No the pipe is PVC and on the second level. The flange is properly positioned above the floor but the portion where the insert gets narrow seems like its cracked. I have seen some pictures on this site showing a line around this section indicating that it should have a seam of some sort but mine seems broken. I tried to post a picture but could not upload it. I'll try again later but for now I'm on my way to Lowes!!
Similar Threads: Possible flange
Toilet Forum discussions Is it possible to rotate the flange? Feb 24, 2013
Toilet Forum discussions Bolts for toilet flange making toilet leveling impossible Nov 20, 2012
Toilet Forum discussions Need assistance with stuck fill valve on polybutylene piping - possible solutions? Dec 7, 2016
Toilet Forum discussions Possible Design Flaw in Toto Drake Toilets: Consider Before Purchasing Jan 9, 2014
Toilet Forum discussions Toilet help! DIY Fixes, if possible Sep 5, 2013
