Posi temp issue with a curveball
Discussion in 'Shower & Bathtub Forum & Blog' started by boss99er, Aug 5, 2012.
  1. boss99er
    boss99er New Member
    Aug 5, 2012
    Omaha NE
    Posi temp issue with a curveball thrown in
    Hey guys, I need some help here. I have a shower with a Moen Posi Temp valve. Its installed in a bathtub/shower combo. Lets say for this example I have the handle directly pointed up...right in between hot and cold. If I let the water run out of the faucet, its a nice warm temp with no issues. I can adjust it colder or hotter and the water temp responds as it should. If I pull the diverter and make the water run out the shower head, it gets full hot without moving the handle at all. If I move the handle to colder, there is no response. There also seems to be a change in the sound of the water rushing through the valve. If I push the diverter back down and let it come out of the faucet again, without touching the handle it goes back to being a nice warm temp like it should. When it goes back to warm, I can hear a change in the tone of the water going through the valve again. I figured it was just a faulty cartridge, so I purchased a brand new cartridge and popped it in. No change.
    Any ideas? Thanks in advance!
  2. jimbo
    jimbo Plumber
    I suspect the balancer is unable to fully react to some pressure changes due to the large difference in volume flow between shower and tub. It should, of course, so the first step I would do is is get an inexpensive pressure gauge at the hardware store, connect it to a bibb or faucet on the house side of your regulator, and measuer both static ( no water running) and dynamic ( some faucet full on) pressures. These readings may be informative.
  4. boss99er
    boss99er New Member
    Aug 5, 2012
    Omaha NE
    Hmm...ok...but what would make this change so suddenly? I can't say for sure, but it seemed to start around the time we put a new wand style shower head on that shower. Neither my wife or I can say for sure that's when it started. Could that cause this issue? When you mentioned volume difference, could the restriction in flow to that shower head cause this? Are posi temp valves sometime incompatible with certain shower heads? I know everything now days is super low flow...
  5. boss99er
    boss99er New Member
    Aug 5, 2012
    Omaha NE
    I'm going to Lowes over lunch to buy a pressure tester. Since the hydrants on my house are after the meter, they should work for the test, correct? What should the levels be for static and dynamic?
    Also, thanks for the help!!!
  6. boss99er
    boss99er New Member
    Aug 5, 2012
    Omaha NE
    I should also note this. This morning I was taking my shower and before I was done, I turned the handle to almost full cold. The water stayed full hot. It was tolerable, because I turned my water heater way down so we could at least continue showering until this is fixed. Anyway, I turned it to almost full cold, and the water stayed hot. I pushed the shower diverter down and immediately the water coming out of the faucet was full cold. Its so odd! This has be really baffled!
  7. boss99er
    boss99er New Member
    Aug 5, 2012
    Omaha NE
    Ok, tested the water pressure at an outside hydrant that I know is on the house side of the regulator and meter and it was 85 static, and about 83 dynamic. That's pretty high right?
  8. boss99er
    boss99er New Member
    Aug 5, 2012
    Omaha NE
    I decided to test on an actual faucet in both of our bathrooms and static was 85 and dynamic was about 78. Still too high though for the posi temp?
  9. jadnashua
    You're on the edge where code requires a pressure reduction valve (normally 80psi). But, the valve should work at the pressures you have.
  10. boss99er
    boss99er New Member
    Aug 5, 2012
    Omaha NE
    Well then I'm at a loss for what could be causing this. Looks like its time to call a plumber and see if they can figure it out.
  11. boss99er
    boss99er New Member
    Aug 5, 2012
    Omaha NE
    Is there something else I should check off the top of your heads?
  12. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    i would call moen and see what they have to say.. they have great customer service from my experience. an easy test is try a different shower head, as this seems to be causing your problem...maybe if you have your old one to pop back on and see if it works
  13. boss99er
    boss99er New Member
    Aug 5, 2012
    Omaha NE
    I'll give them a call today and see what they say. I would try the old one, but we threw it away when we changed to the new one. I knew that was a bad idea! Ha ha. Basically, we replaced a large faced normal shower head with a wand type. I tried removing the restrictor in the wand head to see if that made a difference. No luck there either.
Similar Threads: Posi temp
Shower & Bathtub Forum & Blog Is this a picture of a Moentrol or Posi Temp Valve? Nov 15, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp Valve Identification Jul 16, 2016
Shower & Bathtub Forum & Blog Shower remodel layout. Two Moen Positemp Valves Jun 5, 2016
Shower & Bathtub Forum & Blog Moen posi-temp problem Apr 1, 2016
