Porcher Veneto toilet repairs
Discussion in 'Toilet Forum discussions' started by Terry, Jan 5, 2005.
  1. Terry
    Aug 17, 2004
    From Gordon by email:
    I am trying to replace the piston assembly on a Porcher Veneto.
    I have the replacement piece but I cant figure out how to get the old
    piece out. If you look at the diagram at
    http://www.terrylove.com/pdf/veneto_parts_3362.pdf
    I have parts 4 & 5 removed, but I cant seem to get part "6" unscrewed
    from the tank housing. It's loose but will not come out? There is
    obviously a nut on the other side but I cant get it free. How do I
    unscrew this bugger? Is there a tool I am missing? Do I have to remove
    the whole tank to get this out? I have the replacement pieces and it
    looks like there is a nut (unnumbered but is on the diagram) and a
    gasket (#7)
    Yeesh, I am longing for the old flapper days. Did I get a lemon in this
    porcher it has only been in for less than a year....
    Obliged for your help!
    gordon
    http://www.e-onlineplumbingparts.com/porcher_toilets.htm
    [​IMG]
  2. RobW
    RobW New Member
    Apr 27, 2005
    Did you ever get this fixed? I've got a Porcher Veneto that's about 2 years old and also needs the valve replaced. What's the deal with these puppies? If they were cars, I'd think they'd be recalled
    TIA,
    Rob W
    [​IMG]
  4. tmcauliffe
    tmcauliffe New Member
    Feb 7, 2007
    How does the upper valve housing come off the assembly? Is it the two tabs on either side. Also, did you ever get the lower valve housing off? Finally, where did you get the replacement parts. TIA.
  5. sammysson
    sammysson New Member
    Mar 30, 2007
    Illinois
    veneto- Getting rid of mine-
    I have 4 of these toilets, they are nothing but costly with continuous maintenence. the piston just pulls off once you ave removed the upper portion, I have to replace this once every 6 months at a cost of $30 each, after 3 years i now must replace all the valve membranes at a cost of $18 each. The problem is the silicone gaskets which fail to seal after a while. I am planning on replacing all of them. However thet no longer sell just the gaskets. I figure I have already bought a new toilet with all the replacement parts. Additionally the lost water from the run through when the gaskets fail drives me nuts.
    :mad:
  6. ha1976
    ha1976 New Member
    Sep 12, 2007
    Porcher Veneto Parts That Wear Out
    I got the three Porcher Veneto toilets in my house because of the fine European look, not knowing that the 2 parts that normally wear out are not easily obtained in this country, yet widely available in Europe, made by GroheDal. The shut off membrane (GROHE 4375800M), also called "membrane assembly 83086.00.000" or "diaphragm gasket" normally lasts up to 5 years and can be easily replaced by unscrewing the large white knob of the supply tower; the discharge piston (GROHE 43544000), also called "piston assembly 83084.00.000" or "flush valve" lasts longer, but is a source of water leakage due to the deteriorated silicone seal. Both can be obtained at a fair price from Guillen Enterprises in Miami, FL, and the online service is very professional. Once you have a supply of these two parts in the house, your Veneto toilet will continue to function well while adding an elegant esthetic touch to your residence.
  7. matt c
    matt c New Member
    Sep 17, 2007
    Just an update for all who have leaking porcher veneto toilets.. I have a 11-year old porcher, so I called Porcher at 1-800-359-3261 in regards to my leaking veneto.. They transferred me to a technical support specialist who said I either needed a new flush piston, aptly referred to as a piston assembly 83084.00.000 by ha1976, or a new membrane. They sent me both..
    My leak was due to the piston assembly (flush piston). The piston sits inside the upper valve housing. The upper valve housing comes off by twisting the upper housing counter-clockwise. When you lift the valve housing out of the tank you will see the flush piston extruding from the bottom of the housing. The flush piston can be pulled out of the housing.. Yes, it just pulls out. And you just push the new piston in place.. Secure the valve assembly back into the tank by rotating the housing clock-wise.. By the way, my veneto has two clips on the housing which secure the housing in place.
    Hope this helps. And thanks to everyone on this site who gave me enough info to fix my leaking veneto.. Cheers to the tech specialist at Porcher who helped me too.
  8. Dennis F
    Dennis F New Member
    Oct 20, 2007
    Thanks to 'HA1976' for the excellent information!
    Our Porcher Venetto was installed about 10 years ago and has proved to be an exceptional fixture. The flush siphon/valve is very well designed & strong. However, we have hard water (high caco3) sod I replaced the parts as a precaution. No seeps and No leaks.
    I did find the parts easily available in France/Germany but did not know the Grohe order numbers for these inexpensive two replacement parts! American Std., the parent company, supplies parts, but they're pricey. THANKS for the Grohe order numbers !!
    Dennis
  9. Andy009
    Andy009 New Member
    May 29, 2008
    Porcher Veneto toilets parts
    I'm soooo glad I found this forum! thanks to all of you I was able to find the parts I have been looking for.
    The water tank leak and the shut off valve problem will soon be fixed once my parts arrive.
    thanks again guys! :)
    Andy -
  10. waldo123
    waldo123 New Member
    Jul 30, 2008
    porcher veneto
    I've got 2 porcher veneto II's, both about a year old.
    The flushing handle sticks down on both, when flushing, unless you flush it "quickly" (push it down fast and don't hold it down long). Is this an adjustment issue or a porcher veneto personality trait?
    Also, the slow close lid on one of these puppies is now a fast slam. Again, another adjustment item?
  11. anchange
    anchange New Member
    Oct 9, 2008
    porcher veneto 1 toilet parts
    It seems that the flush valve assembly on my porcher veneto 1 toilet isn't working. The tank drains constantly and sometime there's a vibrating sound coming from the piston. I called Porcher and they can only sell me the piston not the entire valve assembly. I'd like to buy the whole thing so that I know the problem gets fixed. Any suggestions on where I could find a replacement full valve assembly or advice on my problem? Thanks in advance for the help!
    Brad
  12. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
  13. edk
    edk New Member
    Aug 11, 2009
    Aurora, Colorado
    porcher veneto parts
    I've had 3 Porcher Venetor toilets for 9 years. I LOVE them. They are great and have been maintenance free for 9 years. I now have one that requires the membrane to be replced cause I was cleaning out the inside and accidetally ripped the membrane. The parts are easy to take out, clean and replace. Much easier than the old fashioned toilets with the flapper and chain.
    Thanks to this site and the posts, I found where I can purchase them at a resonable price, 10 for $10.95 (membrane) The Porcher is now owned by AmericanStandard, and buying parts from them is ludicrous. They're expensive and take forever to ship.
    I am however looking for a parts conversion from Porcher to Grohe, since Grohe makes the Porcher parts. Does anyone know where this can be found? I'd like to have on hand a few spare parts like the gasket. Thanks
  14. Vikki
    Vikki New Member
    Aug 15, 2009
    We have an old Porcher Veneto which has served us well, but recently it started to vibrate and shake. If I wiggle the upper valve housing, I can stop it. I'm not sure if the gasket is the only thing I need to replace or if I need to replace the whole piston assembly. Any ideas? Also, does anyone know the Grohe part numbers for these?
    Thank you very much!
    Plumber Vikki
  15. edk
    edk New Member
    Aug 11, 2009
    Aurora, Colorado
    Porcher Veneto parts
    Grohedal parts are cheaper than then Porcher part numbers
    Grohedal
    38029PIO complete fkush valve assembly
    43544 piston assembly
    43745 gasket
    37092 water control assembly
    43733 membrane, A package of 10 is <$10, whereas at American Standard parts, they charge you $19.95 for just one
    Porcher Veneto part Numbers from American Standard
    83081.00.000 complete flush valve assembly
    83084.00.000 piston assembly
    83088.00.000 gasket
    83082.00.000 water control assembly
    83086.00.000 membrane
  16. innkeeper@willows-inn.com
    innkeeper@willows-inn.com New Member
    Sep 15, 2009
    Lummi Island, Wa
    Thanks for your help
    Thanks so much for this forum! I have been at a loss to figure out why my venetto leaks. It looks like the gasket on the piston assembly has a knob on it that allows water to leak through. I can't see how a new piston assembly will change that, but I'll give it a try. I have used Guillen out of Miami once before, with very good luck.
  17. Mad Plumber
    Mad Plumber Mad Skills
    Aug 13, 2005
    Plumming
  18. serglo@sbcglobal.net
    serglo@sbcglobal.net New Member
    Oct 3, 2009
    The Woodlands Texas
    Gordon did you ever replace the gasket,if so could you tell me how.
    Thank you
    [​IMG]
  19. 808liz
    808liz New Member
    Jun 4, 2011
    Honolulu,HI
    How do I replace the fill membrane?? Does the front piece just pull off??
  20. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    Bumping this old thread.
    Any updates on the Porcher toilets.
    I am looking to add a Veneto Ii to our house.
  21. Rongway
    Rongway New Member
    Jul 23, 2012
    Illinois
    the fill membrane is accessed by unscrewing the big white round nut that is attached to the fill arm.... the nut is about 1 1/4 inch.. you can see it in the diagram. it has no reference number and it just above and to the right of the "9" in the diagram.
Similar Threads: Porcher Veneto
Toilet Forum discussions Porcher Veneto II that vibrates and leaks Feb 14, 2009
Toilet Forum discussions old porcher veneto gpf? May 13, 2006
Toilet Forum discussions Leaking Porcher Veneto Feb 26, 2006
Toilet Forum discussions Porcher Archive one-piece performance Aug 4, 2013
Toilet Forum discussions Toto Colonial White Matches the Fireclay White of your Porcher Pedestal Apr 24, 2013
