Hello, all!
I purchased a new Delta sink faucet and drain assembly. Looks great, but the pop-up drain will not hold water.
I'm positive that the drain portion is the leak, not the underside of the "lip" surrounding the pop-up. If I remove the pop-up and plug the hole with a rubber plug, the water stays.
I've tried flipping the rubber seal so that it touches the metal "top" but that doesn't work either.
I'm at a loss as to what to try next. Thanks in advance for any advice.
