Poor water pressure with new tub/shower set......HELP!
Discussion in 'Shower & Bathtub Forum & Blog' started by virtualblues, Jul 7, 2010.
  1. virtualblues
    virtualblues New Member
    Jul 7, 2010
    Vancouver, WA USA
    I replaced an old, leaking American Standard tub/shower set with a new American Standard #3275. Since the replacement, the tub/shower flow, both hot and cold, is just 1 gallon per minute. Takes FOREVER to fill the tub, 5 minutes to fill a 5-gallon bucket. When I pull the valve stem and let the pipe flow open it blasts out about 8 - 10 gallons per minute - much like Old Faithful. I'm suspecting the valves are too restrictive. Went to Home Depot, where I purchased the fixture. They couldn't explain the lack of pressure nor do they stock replacement parts. Called American Standard and they said the new valves are obstructed with debris. They are sending me replacements valves, which is nice. However, I completely disassembled the valves I have and they are as clean as a whistle nor is there debris backed up behind the valves. I need plumbing advice. Any and all appreciated. Thanks. pk
  2. hj
    we would have to be there to check it out. The shower head could be restrictive, but that would have absolutely no effect when filling the tub. As an aside, I try NEVER to use American Standard valves.
Similar Threads: Poor water
Shower & Bathtub Forum & Blog Low Pressure and Poor Hot Water in Master bath Dec 28, 2009
Shower & Bathtub Forum & Blog Poor Water Flow After Replacing Stems Aug 28, 2008
Shower & Bathtub Forum & Blog Best type of shower mixing valve / highrise bldg with poor pressure balance Dec 21, 2016
Shower & Bathtub Forum & Blog Poor flow in tub/shower May 8, 2016
Shower & Bathtub Forum & Blog Fixing poor tub surround - how to seal vertical gap? Nov 24, 2015
