Poor Flush, Kohler Memoirs toilet
Discussion in 'Toilet Forum discussions' started by BMWMK2, Jun 2, 2007.
  1. BMWMK2
    BMWMK2 New Member
    Feb 4, 2006
    Hi Everyone I Have A New Kohler Memoirs 2 Piece Toilet. The Flush Is Rather Poor And It Clogs When The Kids Use The Toilet, Now If I Hold The Handle Down And Let All The Water Drain To The Bottom There Is Never A Problem. How Can I Adjust The Toilet To Do That Automaticly?
    [​IMG]
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Fill valves can be adjusted to raise the water level in the tank. Flappers can be adjusted to allow more water to leave the tank. They also sell adjustable flappers. Some have a styrofoam ball that you can raise or lower to allow more or less water to leave the tank.
  4. Terry
    Aug 17, 2004
    The easiest solution would be to get a longer timed flapper.
    However, if the bowl does plug, and the water keeps draining from the tank, the bowl can overflow. If it does, get the mop out.
  5. BMWMK2
    BMWMK2 New Member
    Feb 4, 2006
    Which Way Do You Go Up Or Down With The Styro Ball To Allow More Water In? And Do The Sell Better Replacement Flappers, What Brand? Thanks
  6. Verdeboy
    Jun 12, 2006
    The best flapper is the Korky red. It works fine for most toilets. But you still need to adjust the chain. You might be able to adjust the chain on the flapper you already have if it closes too fast.
  7. jadnashua
    As long as the chain is adjusted to fully open the flapper valve, and allows it to close fully, there is nothing else to adjust on the chain. If it has too much slack, it can get caught under the flapper, creating a leak, or not open it enough to perform the designed flush.
Similar Threads: Poor Flush
Toilet Forum discussions Poor flushing toilet w/ low sloping drain Jun 21, 2014
Toilet Forum discussions Champion 4 Poor Flush - Revisited Jan 27, 2010
Toilet Forum discussions Champion 4 Poor flush Dec 28, 2009
Toilet Forum discussions Toto Toilet ~ Poor Flush Jun 5, 2007
Toilet Forum discussions Poor Flush & Bubbleup Apr 29, 2007
