Polyethylene sizing for general watering needs
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Smith333, Nov 23, 2011.
  1. Smith333
    Smith333 Member
    Sep 5, 2006
    Wisconsin
    Next spring I would like to bury about 220 ft of PE in the yard for general watering needs. This will replace an equal length of garden hose that has to be removed everytime the lawn is cut. The line starts flat, then goes downhill, with the outlet being about 10 feet lower than the source. The house plumbing is 3/4" copper.
    My objective is to have a flow rate at least comparable to the existing garden hose setup. Will 3/4" PE fit the bill? Or would the barb fittings constrict the flow enough to make it worth using 1" PE instead?
  2. Terry
    Aug 17, 2004
    220 feet is a lot of friction loss.
    If you have a few sprinklers then 3/4" may not be bad, however if it's upsized, then you would have the option of putting in irrigation with controls.
    For an example.
    A home with 250 feet of 3/4" line, too little volume to run a six head system opening at the same time.
    By changing the line to 1.5", easily produces watering all the way to the end with that many heads.
    It's the same ditch and the same labor. Running PE, you may want to think about 1-1/4" if you go that route. 1" at the minimum.
  4. hj
    You have to specify if your PE is ips or cts. Cts plastic, of any kind is about the same size as 1/2" copper, as far as the water is concerned. In any case, the size of the pipe depends on HOW many heads are connected and the flow rate needed for them. Usually irrigation systems are run with 1" to the control valves and then either 1" or 3/4" after the valve to the heads, with the final connections being 1/2". You are probably NOT going to connect the new line to the hose faucet, so you MUST have a "pressure backflow preventer", at a minimum, at the connection to the house system.
  5. Smith333
    Smith333 Member
    Sep 5, 2006
    Wisconsin
    Thanks for the replies. I need to clarify that this isn't for a formal irrigation system, but rather something that will have only a single sprinkler or nozzle operating at a time. I'm trying to replicate the output that a single garden hose would provide. We're on a deep well and irrigation is out of the question. I guess I'll have to start comparing the ID of the different components to see what will be necessary.
  6. hj
    A "minor" restriction, such as an insert fitting, has little effect on the final volume because the flow's velocity will increase through that small distance to compensate. It is when the restriction occurs over a "long" distance, such as an undersized pipe, that it becomes a major factor.
Similar Threads: Polyethylene sizing
Plumbing Forum, Professional & DIY Advice 225' of sump pump drain to run... PVC or polyethylene? Jun 9, 2014
Plumbing Forum, Professional & DIY Advice Ferrule for polyethylene compression fitting Nov 30, 2012
Plumbing Forum, Professional & DIY Advice Rodents and Polyethylene pipe Mar 31, 2012
Plumbing Forum, Professional & DIY Advice new 1200' polyethylene water line questions Feb 15, 2011
Plumbing Forum, Professional & DIY Advice Copper vs. Polyethylene/PEX pipes? Nov 13, 2010
