jumpenjuhosaphat
- Messages
- 1
- Reaction score
- 0
- Points
- 0
I was referred to this forum by a member at JLC....
I installed a water heater yesterday in a mobile home. The entire plumbing system uses the grey polybutelyne line, which part of needed to be replaced because of fire damage. I used cpvc to replace the damaged plumbing, but making a connection to the polybutelyne has turned out to be difficult at best. First, I used PEX adapters with hose clamps, but the hose clamp proved to be inadequate...Then with a bit of tinkering, I discovered that the poly had the exact same O.D. as the cpvc, and fit snuggly into the cpvc fittings....I used purple primer to clean the poly, and orange cpvc glue to make the connection, but even after an hours time to set up, I could still pull the connection apart with my hands with a little effort. The cpvc cement is holding up so far under pressure, but my guess is that it won't for long. Are there any inexpensive solutions to this problem, as the poly has been recalled and I can't find parts to adapt it to a cpvc system.....Is there an adhesive that will bond cpvc to poly? That would be the simplest way to handle this.
