pocket doors and air leakage?
Discussion in 'Remodel Forum & Blog' started by ctreefer, Feb 1, 2013.
  1. ctreefer
    ctreefer New Member
    Sep 11, 2012
    CT
    So I'm still trying to attack all means of air leakage into the attic space and started to wonder about my pocket doors in the house. We have 3 pocket doors all on interior walls. From what I can tell by their construction that pocket would let warm air get into my wall cavities and then find any cracks in the framing to get into the attic. Would this be correct? Should I pull back the insulation in the space above and seal the seams around the top plate?
  2. hj
    You are being paranoid. The top plate should be tight to the drywall on either side, UNLESS it has wires or pipes passing through it, and those should have been sealed when they were installed.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Best building practice here is to sandwich a strip of poly between the two top plates and then to use acoustical sealant to seal it to the rest of the poly. Of course, other penetrations get sealed as hj described.
    Dry contact of the poly to the top plate alone does not assure a good seal. My spec build former home used that method on interior partitions into a cathedral ceiling and had problems with condensation dripping from those rafter bays that had partition walls. An attic would not suffer the same problem.
    Depending on the type and colour of insulation in your attic, you may be able to see if/where there are air leaks by the insulation discolouring. Smoke pencil tests around the edges of the doors may suggest leakage into the attic or may be room-to-room air movement.
  5. Windows on Washington
    Windows on Washington Member
    Sep 25, 2012
    Exterior Construction
    Washington, DC
    Great post.
    You nailed it 100%.
    Google Air sealing and insulation and you will be overcome with information.
Similar Threads: pocket doors
Remodel Forum & Blog Lock for Bathroom Pocket Door Aug 20, 2010
Remodel Forum & Blog Pocket door gap Apr 27, 2008
Remodel Forum & Blog Pocket door Question Mar 14, 2007
Remodel Forum & Blog Pocket Door Oct 10, 2005
Remodel Forum & Blog Undercutting Doors Jul 11, 2012
