As can be seen in the photograph, there is a leak that looks most likely to be the result of a bad pipe. I know the pipe on the left is a soil stack, but I am a little unsure of what the pipe on the right is. The unit upstairs has a bathroom with sink, tub, and toilet, as well as an adjacent laundry room with washer dryer. Is the pipe on the right a stand pipe or an extra drainage pipe? What does IPC say about how many fixtures can be attached to a soil stack before an extra stack is require? For a commercial building, what are the common diameteres for the water supply lines? The pipe on the right isn't a supply line is it? Do supply lines get run next to drain stacks? Any information would be greatly appreciated.
