Plunging a TOTO Drake
Discussion in 'Toilet Forum discussions' started by DougH, Jan 30, 2008.
  1. DougH
    DougH New Member
    Jan 27, 2008
    I am trying to decide on which Toto toilet to buy. I like the Drake but I read somewhere that the shape of the bowl makes it almost impossible to plunge in the the event it ever does clog. Is that true? Or was it a different Toto model?
  2. Terry
    Aug 17, 2004
    It would be hard to find a bowl today that does not have a 2" or smaller outlet on the bowl.
    Plungers have either a 2" end, or the black rubber plungers have a 2" pullout on the end.
    Either way, with any brand of toilet, you would leave a little water in the bowl, and use the small end of the plunger in the bowl.
    Using small strokes up and down, basically vibrating the water, then slightly pulling up a bit.
    Normally the water will suck down at that point.
    Many of the better toilets would rarely need plunging, and the Drake is very good. If they do need plunging, its just like the rest, it still uses a plunger sold in any hardware store.
    [​IMG]
    This is the best plunger to use. It is soft rubber with a pull out small end. It's a "one" hand operation.
  4. frogman
    frogman New Member
    Mar 7, 2013
    MA
    It's true that that the configuration of the Drake bowl is not very plunger friendly- a round plunger is not happy trying to seal an oblong bowl.
    For those rare Drake occasions when a plunger is needed, I've had success using a large round corrugated plastic plunger positioned at the back of the bowl, while using an old thick hand towel to seal the gap in front of the plunger. A two gloved hand operation, but it works.
  5. jadnashua
    One key thing Terry said...get the water rocking then quickly pull UP...don't try to force things down. It got stuck by it trying to all jam into a smaller area in the trap. By pulling up, things can rearrange themselves, and then will take an orderly exit rather than trying to jam more into that smaller space that caused the blockage in the first place. Makes a lot of sense when you think about it, but most people try to jam it in tighter...takes a lot more work, and sometimes just makes it worse.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Two questions for the OP. How do you clog a Toto? and what's a "plunger"?
Similar Threads: Plunging TOTO
Toilet Forum discussions Plunging a Toto Drake? May 25, 2016
Toilet Forum discussions Plunging a Toto Aug 27, 2005
Toilet Forum discussions Plunging easier in Round or Elongated Toilets? Jan 25, 2009
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Tuesday at 3:44 PM
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
