Plumbing walls ( Not that kind of plumb)
Discussion in 'Shower & Bathtub Forum & Blog' started by ShowerDude, May 20, 2014.
  1. ShowerDude
    ShowerDude Showers
    Apr 7, 2014
    Minnesota
    I have seen some unfortunate tile installations, especially uneven bad tub deck reveals, and horrible changes of plane in the corners.......it almost always directly reflects the price the homeowner paid.
    Whether its a tub surround alcove, or a 3 wall capture shower, 4 wall capture, neo angle wall or ceiling. Especially if its a Remodel (and in many cases new construction) you should spend time getting your walls and ceiling....
    A. Plumb
    B. Square
    C. In plane
    D. Level (ceiling , tub deck, floor perimiter)
    This is a skillset that is hard to understand and master especially in a neo angle build, it should be something your tile shower builder should talk to you about, This may reflect the difference in the price you get quoted from one contractor to the next...
    Many pros can still float out mud walls perfectly meeting all the criteria above, but that is a skill unto itself and not recommended for a novice, so we find that cement board or other CBU type materials can be manipulated with shims. Among other things this may require some additional framing, blocking and you should pay close attention how far out you "fur" your walls and be sure to compensate with longer fasteners/screws..
    Taking the time to get this right "First" will result in the best visual outcome and actually help you speed up the layout and tile setting process while minimizing your need to "float" your tile, it will help you end up with even reveals throughout your installation and you will be glad you payed the extra time and or $ to do this ( you just dont know it yet!)..
    If you are installing say small mosaics and even 3x6 subway you need to have flat in plane walls.
    John? can you work up a nice graphic detail of what this all means to the DIY homeowner or unskilled tile person?
    Roberto, How do you get your walls Plumb, square and in plane...?
    Jim please refrain from the obvious installation manual pasting.....and thanks in advance JIM
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Counter Balance it really depends on the time line.
    The client.
    And what the setting materials will be.
    Lots of time we tweak the wall studs with door skin. Some times we scab on new 2"x4" 's to fix wall studs. But the real winner is my power planner.... That tool kicks ass and the wood chips go flying....
    Of course I'm not suppose to use the power planer the way I do (deviates from printed instructions) - but it does tear up the high spots nicely.
    But in the end the tile choice and setting material dictate the prep needed a framing.
    And Jim please respect Counter Balances request. None of the boys here want to here from you...
    I just got a great ideal for a new graphic! LOL - I kill myself
  4. ShowerDude
    ShowerDude Showers
    Apr 7, 2014
    Minnesota
    John, Thats to simple an answer( planer excluded! I just hate ruining my planer drum/blade on nails......).
    We all know that 1" or mini mosaics require a flat in plane surface ( penny rounds on dental floss mesh come to mind!!)
    Now a big 12x12, 12x 24, or say 4x4's even Us pros can float as we set.... but the novice cant float typically.( whats floating?) .......So If I am prepping a shower or tub alcove for say A client that intends to tile it themselves like we see here on Terrys site looking for tips...DIY, or A general contractor that has just a decent tile setter... Im getting plumb, square, and in plane for the extra hour or 2 involved I think it saves the installation at times ..........the end result wins both ways? NO?
  5. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    I think so.
    The more even the better.
    That and mixing lots of small batches so the thin-set stay fresh and consistent.
  6. eurob
    eurob master tile and stone installer
    Feb 16, 2013
    Montreal
    CB , most of the time I am not involved in building the wall -- already prepped -- , too late for studs correction . In this case , I usually do it with the Ultralite , same technique as floating with mud .
    Budget is always too low and prepping is not even considered -- time frame and necessity -- .
    This is a ceiling in need of prep . 1'' in 4' -- carpenter said everything will be perfect .
    And there are some tiles in need of cleaning -- wash one by one -- before installation . Also not in the budget , but no way around it .
    Problematic tiles -- washing needed 003.jpg Before
    Problematic tiles -- washing needed 013.jpg Before and after .
  7. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Nice work Roberto.
    Hows it cut?
Similar Threads: Plumbing walls
Shower & Bathtub Forum & Blog Plumbing in outside walls Feb 6, 2008
Shower & Bathtub Forum & Blog Two Shower Heads, No tub. Simple Plumbing ??? Wednesday at 12:50 PM
Shower & Bathtub Forum & Blog Tub Spout Plumbing Jan 14, 2017
Shower & Bathtub Forum & Blog Freestanding Bathtb plumbing apprval Aug 15, 2016
Shower & Bathtub Forum & Blog Shower remodel plumbing dilemma Dec 8, 2015
