Plumbing venting system
johnbin
Florida
I am finishing the work from a plumber I hired who disappeared. Besides the point really but now I am trying to move this forward until I can find a new plumber to help finish this workshop. I am trying to figure out the venting system and have attached a crude picture of what I am considering doing. The main question is, Can I tie into the main vent stack for the upstairs bath or will that be considered wet venting? What I have drawn out connects the upstairs to the aux drain (far left) and then ties the vent from this stack to the main vent. Happy to explain further so ask away with more specifics if that would help. I am fine with the details in each bathroom, just the venting is a little confusing to me.
johnbin
Florida
Ok, so can I run the upstairs bath drain and vent to the main stack and not use the aux? See attached.
johnbin
Florida
it seems from your picture attached hat this drain is a vent above and a drain below. can i drain into the stack under the vent attment?
No, that is a vent that ties into a vent. There is not tying of vents to wet stacks. I think you need to bring back the plumber.
johnbin
Florida
Ok sorry my question seems to be bothering you but as I mentioned in the first post, my plumber disappeared and I am in the process of finding a new one but don't want to just leave everything.
Isn't the drain from the sink the same pipe / or in line with the same pipe as the vent for the sink? please see attached.
What bothers me is your drawing, not mine.
My drawing is correct, yours is not.
index.php
In this drawing, you are tying the vent in "below" the flood level of the fixtures above. The downstairs bat need to go up to the second floor at 42" above that floor. Not below the floor.
johnbin
Florida
I circled a vent on your drawing that is below the upstairs fixtures. Does this one not count?
That does not count. There is no waste going down that pipe. It's a vent all the way through the roof.
On your drawing, you are connecting to waste lines. On mine, I'm connecting to vents.
If you can trace those pipes upward and "see" it, you will need to find someone that can.
It's okay, I can't speak spanish or french, and I get by with what I can do.
johnbin
Florida
Not sure where the difference is. There is no waste entering my pipe above the vent, same as your drawing. What am I missing?
Mike Garrod
Mike G
British Columbia
It's all to do with code. The reason is that if there was a blockage in between your stack and where you downstairs bathtub ties in, it would back up the stack, and into the vent serving your lower bathtub, and even when you got it unclogged, your vent would most likely be full of crap. When you tie your vents in above the flood level rim of your fixtures, your tub, sink, or whatever will overflow, but your venting system will not be compromised.
Cwhyu2
Consultant
Cincinnati OH
You want to tie into the vent stack. a vent stack does not receive any waste no mater what branch level it is as long the vent serving that fixture or bathroom group rises above the flood level rim of the fixture it is serving before going horizontal.
johnbin
Florida
So it seems like connecting to the aux drain and running a vent from the aux drain to the stack is the better solution.
johnbin
Florida
Isn't this sink draining into the vent stack?
Cwhyu2
Consultant
Cincinnati OH
The 4" stack on the left what does it serve is it a vent through the roof, or does it serve as a waste or soil stack.
In other words does it have anything draining into it and is attached to the vent through the roof.
johnbin
Florida
Right now nothing drains into it and it stops at the ceiling of the 1st floor. It was put in for the upstairs bath to drain into but I was hoping to be able to drain that bath into the main stack.
johnbin
Florida
No look at the whole drawing, study it like I did for 5 years of school and on the job training the you may be able to under stand
I am not sure why this is so cryptic, either that sink is draining into a pipe that is acting as a drain on the lower section and has a vent above it or not.
