Plumbing through floor - new vanity
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by VAwife, May 2, 2007.
  1. VAwife
    VAwife New Member
    May 2, 2007
    We want replace our current double sink vanity however I noticed that the plumbing is through the floor rather than the wall. The wall separates the bathroom from the master bedroom and is only 2? inches thick which is why I'm assuming the plumbing is through the floor.
    How do I need to factor in this plumbing set up with picking out a new vanity. If I do a open space vanity on the bottom does that mean all my plumbing will be exposed? Or if I get a cabinet vanity is it going to have to be cut/gutted to fit plumbing - or is there another option? Here's a link to one of the vanities I'm considering ordering.
    http://www.exoticbathrooms.com/PhotoGallery.asp?ProductCode=SJ%2D829AU
  2. Terry
    Aug 17, 2004
    I would make the wall thicker behind the vanity, then the pipes can be in the wall.
    With nice cabinets like that, you don't want to see the pipes.
    Plus, those cabinets hang from the wall.
    You will need more structure than what you have.
  4. VAwife
    VAwife New Member
    May 2, 2007
    how thick?
    How thick of a wall would you recommend?
  5. Terry
    Aug 17, 2004
    The smallest I would go would be a 2x4 as long as you haven't cut large holes through it.
  6. hj
    cabinet
    You are looking at a medium sized remodeling job to use that cabinet. First you will need a "real" wall, then the plumbing has to be routed into it, including some provision for a vent.
Similar Threads: Plumbing through
Plumbing Forum, Professional & DIY Advice Plumbing comes through floor at an angle Jul 1, 2015
Plumbing Forum, Professional & DIY Advice Re-plumbing house, runl Pex through joist or under the joists? May 12, 2013
Plumbing Forum, Professional & DIY Advice Plumbing Installation through floors for sewer pipes Oct 7, 2006
Plumbing Forum, Professional & DIY Advice Noise from basement through plumbing chase Jun 23, 2006
Plumbing Forum, Professional & DIY Advice Replace tub spout, New to Plumbing Jan 28, 2016
