Plumbing reno, is it up to code?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mmmm, May 8, 2011.
  1. mmmm
    mmmm New Member
    Apr 9, 2010
    British Columbia, Canada
    Hi All,
    I am in the process of submitting our plumbing plans for our permit. I thought I would present the plan here first for thoughts/critiques/ideas.
    The house is 51 years old with two existing bathrooms and one additional bathroom. the house is long with a vault in thhe centre hence some vents cannot connect.
    The bathroom in the lower left of the drawing has two sinks, toilet,shower and a BT. There is also three large windows and a stone fireplace in the bathroom which caused a lot of issues with running vents.
  2. hj
    After a cursory review, the toilet and shower vents CANNOT connect together the way you show them. You would have to check the code which applies to your area, but here, if you have three toilets the connection to the main line for one of them has to be at least 15' from the other two or else you need a 4" sewer to the point where it connects. And somewhere you would need a full sized 4" cleanout on that 4" incoming sewer. You might also have a problem with ANY open flame appliance in the bathroom, since you are not allowed to have a water heater there and a fireplace should be even worse.
  4. Terry
    Aug 17, 2004
    And the shower can't be vented by a kitchen sink.
    I plumbing in Washington State, just South of you. If it were here, I would need more venting.
  5. mmmm
    mmmm New Member
    Apr 9, 2010
    Thankyou for the reply. I am assuming you mean by three toilets connecting to the main line, you mean 15' vertically?
  6. hj
    quote; you mean 15' vertically?
    It usually means horizontally, since few homes have 15' ceilings.
  7. tempritespokane
    tempritespokane New Member
    May 3, 2011
    Spokane, Washington
    I'm also a WA plumber and would have to agree that if this set up was for Washington it would require more venting to pass.
Similar Threads: Plumbing reno
Plumbing Forum, Professional & DIY Advice Laundry Room Renovation Plumbing Help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Leaking plumbing to bathroom renovation Nov 21, 2016
Plumbing Forum, Professional & DIY Advice Help With Plumbing Layout For Bath And Kitchen Renovation Apr 28, 2016
Plumbing Forum, Professional & DIY Advice Advice on my reno plumbing layout Mar 28, 2016
Plumbing Forum, Professional & DIY Advice Renovating master bath, need plumbing help! Jan 17, 2014
