Plumbing puzzle
Dasadler
California
I just got this house - has five sinks - 2 in master bath, 1 in main bath, 1 in kitchen, and 1 in guest bath. What’s odd and puzzling is that only two of these five sinks have HOT water… the other three have only warm water. None of them is more than 30 feet from the hot water heater and I did let the water run for a while to ensure and distance between hot water heater and faucet was accounted for.
I am unaware of any physical reason this condition should exist. Does anyone have any ideas as to why?
Smooky
North Carolina
Do you have a mixing valve? Do you have a hot water recirculating system? Do you have single handle, sinks, showers etc.? Do you have both hot and cold water lines connected directly to the washing machine or did you use a Y connect hose? Is there more than one hot water heaters? Which two sinks have hot water?
Dasadler
California
I am not aware of any mixing valve. The faucets are all two handle and water is directly connected to the washing machine. The previous owner says all was good before - the home inspector says all was good. Unless the place is haunted... no reason for it not to work as far as I can tell.
Shut off the water supply into the water heater as a test. Turn on hot water faucets. Does water come out under pressure (not just dribbles)? If so, something allows crossing over.
