Plumbing Problems
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tingeyplumbing, Mar 16, 2012.
  1. tingeyplumbing
    tingeyplumbing In the Trades
    Dec 1, 2011
    Salt Lake City, Utah
    If you want to prevent plumbing problems it’s recommended to try controlling what goes down on the plumbing drain, because cooking grease can solidify and clog drains. But if your drain starts to become clogged you can try to pour chemical-based drain cleaner or lots of boiling water down a sluggish drain to clear it. Before winter comes, turn-off flow to the outdoor spigots, This way you can prevent bursting pipes caused by water left in the lines that subsequently freezes.
    Also, if you’re planning on going away for some time in the winter, remember to leave the heat on, you can turn it way down but don’t stop it and leave the kitchen and vanity cabinet doors open so heat can reach the pipes to avoid freezing.
    Listen for dripping sounds and this way you can discover if you have a leaking faucet. Even though a dripping faucet may not seem to waste significant amounts of water, over the course of day, each individual drop adds up to thousands and thousands of drops, or gallons and gallons of water. Choose a time when there is little or no activity, such as early in the morning, or late at night, when the house is very quiet.
    Also, if you need repairs it’s better to call a professional plumber, especially if you’re not confident in your abilities. Soldering pipes, replacing valves, and changing faucet seats may be better left to skilled persons with proper tools. If you use a chemical drain cleaning product for cleaning clogged or slow-draining pipes make sure you read carefully instructions first. If you have rusty pipes, be careful and don’t force them too much because the problem could get worse.
Similar Threads: Plumbing Problems
Plumbing Forum, Professional & DIY Advice Plumbing problems are baaaaaack Nov 28, 2014
Plumbing Forum, Professional & DIY Advice Plumbing Problems washing machine hook up Apr 13, 2013
Plumbing Forum, Professional & DIY Advice Plumbing problems after shocking well with chlorine! Help Apr 25, 2012
Plumbing Forum, Professional & DIY Advice Bathroom re-model plumbing repair possible problems with old plumbing!!!!!! Mar 11, 2012
Plumbing Forum, Professional & DIY Advice washer plumbing problems Apr 10, 2011
