plumbing over electric panel
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Zenman, Sep 12, 2009.
  1. Zenman
    Zenman New Member
    Nov 26, 2004
    New Jersey
    Is there a restriction on how close the water supply lines can be to the electric service panel? Currently the water supply runs directly above the main panel and I'm doing some renovations and have to move the supply line. So when I replace the line, is there some minimum distance that I need to maintain?
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I never put water piping or ductwork directly over panels. Use some common sense and you should be fine.
  4. hj
    water
    Spacing requirements have to do with possible contact with the piping while working in the panel. If the pipes are overhead there would be little reason to make contact with them.
  5. Cass
    Cass Plumber
    Nov 12, 2005
    What was the distance and what do you want it to be...
  6. Zenman
    Zenman New Member
    Nov 26, 2004
    New Jersey
    Thanks for the replies so far...
    This is in the basement. The panel is against the wall and the supply is 6 inches above the top of the panel and 12 inches in front of it. I was going move it over at least one joist bay (16 inches + the original 12 inches = 28 inches in front of the panel, and still 6 inches above). I could move it an additional joist bay over if necessary.
  7. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    E3305.3 Dedicated panelboard space. The space equal to the
    width and depth of the panelboard and extending from the floor
    to a height of 6 feet (1829 mm) above the panelboard, or to the
    structural ceiling, whichever is lower, shall be dedicated to the
    electrical installation. Piping, ducts, leak protection apparatus
    and other equipment foreign to the electrical installation shall
    not be installed in such dedicated space.
    The area above the dedicated
    space shall be permitted to contain foreign systems, provided
    that protection is installed to avoid damage to the electrical
    equipment from condensation, leaks and breaks in such foreign
    systems (see Figure E3305.1).
    Exception: Suspended ceilings with removable panels shall
    be permitted within the 6-foot (1.8 m) dedicated space
  8. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Yea Jar that's it, that's it exactly :D
  9. Zenman
    Zenman New Member
    Nov 26, 2004
    New Jersey
    OK... from that it seems that no supply lines directly above the panel are allowed. It doesn't specify a distance in front of the the panel, so I guess as long there is some separation I should be good. I was going to be at least 28 inches in front of the panel (if not more), AND above 6 feet, so I shouldn't have a problem.
  10. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Correct, the issue code wise is leaking *and sweating from HVAC* down onto the panel or feeders.
Similar Threads: plumbing electric
Plumbing Forum, Professional & DIY Advice Plumbing and electrical Jan 3, 2016
Plumbing Forum, Professional & DIY Advice Is there a plumbing equivalent to Richter's "Practical Electrical Wiring" book? May 5, 2010
Plumbing Forum, Professional & DIY Advice Question - Plumbing/Electrical Nov 3, 2009
Plumbing Forum, Professional & DIY Advice plumbing and electrical Nov 2, 2008
Plumbing Forum, Professional & DIY Advice Electrical/ plumbing in same stud bay Feb 8, 2008
