Plumbing for toilet valve...
Discussion in 'Toilet Forum discussions' started by I26, Sep 23, 2007.
  1. I26
    I26 Member
    Jul 2, 2006
    Reading, Pennsylvania
    I needed to change out the tank components. I could not shut off the water since the valve seal was shot. I picked up a new valve and tried to use the old compressing ring hoping it would seal. Well over time it must drip. I would like to cut off the pipe behind the compression ring to install a new one but that will leave me with such a small stub I may not be able to get the coupler nut on to attach the new valve. So whats the easy way to repair this?
    I was thinking of soldering on a coupling to extend it then attach the new valve.
    I am not up on all the plumbing terms so please realize that. Any advice would be great.
  2. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    If your going to solder a coupling onto the end why not just solder on a new shut off valve. In the future you could unsolder it and replace.
  4. I26
    I26 Member
    Jul 2, 2006
    I did think of that after the fact. Still if I cut the pipe it will be awfully short, even to solder on a valve.
  5. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    A coupling and a valve have the same amount of space to solder to. One would solder on just as easy as the other.
    I have seen a tool that is used to remove those rings for the compression fittings you might want to look into one. I don't know how well they work but it could be worth the try.
Similar Threads: Plumbing toilet
Toilet Forum discussions What I hope is a simple question about basement toilet plumbing Mar 9, 2015
Toilet Forum discussions Toilet Plumbing in Honduras Feb 20, 2014
Toilet Forum discussions Crane plumbing rear outlet toilet - need to replace wax ring Apr 17, 2013
Toilet Forum discussions Toilet plumbing Dec 7, 2012
Toilet Forum discussions need help with toilet/plumbing issue. Jul 12, 2011
