Plumbing & Electrical question
Discussion in 'Electrical Forum discussion & Blog' started by Rysis, Jan 16, 2012.
  1. Rysis
    Rysis New Member
    Jan 16, 2012
    PA
    Hello,
    I am in the process of renovating a ranch home and I'm considering the installation of a sewage pump in the basement to add a extra bath and wash room. At some point I would like to finish this space for an entertainment area. The question I have run into is that the most direct run to the sewage line would route the pipe in front of the electrical box. Is there a specified distance that I need to be away from the box?
  2. jadnashua
    There are codes that specify clearances, but I don't know the specifics. You may want to post this on the electrical forum.
  4. ballvalve
    Dec 28, 2009
    northfork, california
    I think this is the elec forum. But anyway I doubt it. Some unions or flexible pipe in that area might be kind to the electricians, and get it up tight to the ceiling. Or perhaps a few feet outwards, then elbow back in.
  5. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Not sure if this thread was moved. Maybe could have.
    But you should not have a problem, If it already passed the electrical inspection.
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    The area from the floor to a height of 6 feet above or the finish ceiling and 3 feet out is dictated to the panel and Nothing can be installed in that area.
    What you don’t want is sewage leaking onto the panel.
  7. Rysis
    Rysis New Member
    Jan 16, 2012
    PA
    Thanks for the info everyone!
Similar Threads: Plumbing Electrical
Electrical Forum discussion & Blog Insulating plumbing / grouding wire Aug 8, 2013
Electrical Forum discussion & Blog Grounding questions: Gas, plumbing, appliances Aug 13, 2009
Electrical Forum discussion & Blog Oven outlet next to Bathroom Plumbing Apr 28, 2009
Electrical Forum discussion & Blog Light Switch Behind Plumbing Dec 29, 2008
Electrical Forum discussion & Blog Running a ground wire in conduit to plumbing Aug 10, 2008
