Plumbing drainage question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Larry4, Nov 27, 2008.
  1. Larry4
    Larry4 New Member
    Dec 2, 2007
    Hi all. I was always told never to plumb in a minor fixture under a major fixture(2nd floor toilet over first floor lav) If the first floor lav is seperatly vented up to and above the higest fixture is it ok to do. What exactly do they mean by this?? Thanks for your help.
    Lar
  2. jadnashua
    A pipe should be only one thing, waste or vent. So, if you want to use what is now a vent for waste, you need to provide a new vent for those lower fixtures. This would be a new pipe branch that goes above where those pipes are waste to where they become vents for the items above. typically, you can either run that new vent all the way to the roof, or you can rejoin the vents above...that needs to be done typicall 42" above where they are a waste line (basically it says 6" above where waste could accumulate if the drain was plugged, i.e., the flood plane - but, a typical kitchen counter is 36", so they often want 42" even if it is a vanity which could be lower).
  4. hj
    fixture
    In the first place you could not connect a lavatory on the first floor to the toilet drain from the second floor WITHOUT having its own vent. The ONLY purpose for a vent is to relieve positive or negative pressures. Once you do that, you can connect the fixture to any drain line you so desire.
  5. Larry4
    Larry4 New Member
    Dec 2, 2007
    OK Thank for the info. Not to try and grossly over simplify drain and venting, but to help me better understand it. Given that you use the proper size drain line in (FU) and grade properly. If you are running a horizonal or vertical soil line in residential work, can you tie in all your fixtures as you go as long as each fixtue is seperatly vented up above the highest flood rim by 6". (also not running your vent horizonal before this).
    Thanks,
    Lar
    [​IMG]
Similar Threads: Plumbing drainage
Plumbing Forum, Professional & DIY Advice Very Odd Plumbing Drainage Problem Feb 3, 2012
Plumbing Forum, Professional & DIY Advice Addition Bath Plumbing Drainage? Mar 24, 2009
Plumbing Forum, Professional & DIY Advice Plumbing sink with no overflow. Please help Thursday at 9:02 AM
Plumbing Forum, Professional & DIY Advice Plumbing for a gas water heater Wednesday at 8:22 PM
Plumbing Forum, Professional & DIY Advice Bathroom plumbing question Tuesday at 11:20 AM
