Plumbing Clean out
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Manseau, Sep 2, 2012.
  1. Manseau
    Manseau New Member
    Sep 2, 2012
    thunder bay
    Can this be plumbed as the picture shows or can someone give me some advice on a different way.
    Thank You
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    The clean out is ok but I don't like the double wye on a washer. I'd rather see the washer come into the vertical below that other line if possible.
  4. hj
    IF that is REALLY a vent, then the washer has to connect with a sanitary tee, while the other side MAY connect with a "Y", assuming it is independently vented.
  5. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Plus the washer drain needs to be 2" pipe with vent off after the p trap
  6. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    in ontario 1-1/2" is fine for washer drain..depending on the distance to p-trap for washer you can stack vent with the vent you are tieing into as long as there is no discharge above and you connect to "vent" using a T
  7. jadnashua
    Many of the newer WM pump water MUCH faster than the older ones, and while redoing things, you will be MUCH happier in the long run if you use 2".
  8. hj
    quote; in ontario 1-1/2" is fine for washer drain
    You are confusing a "minimum standard" with one that is adequate under ALL conditions. In the wall washer boxes ALL have a 2" drain outlet for a reason. The washer trap does NOT need an individual vent, IF that riser is truly a vent and not a drain from upper floor fixtures. Another thing we do not know is what the right hand pipe that "goes into the ground" does or is for.
Similar Threads: Plumbing Clean
Plumbing Forum, Professional & DIY Advice Would appreciate a review of my plumbing layout and esp. cleanout on horizontal runs Mar 8, 2016
Plumbing Forum, Professional & DIY Advice Bathroom plumbing question Yesterday at 11:20 AM
Plumbing Forum, Professional & DIY Advice Plumbing with PEX, which option to choose Monday at 6:05 PM
Plumbing Forum, Professional & DIY Advice Plumbing leak on plastic pipe Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Very Strange Plumbing Issue Feb 15, 2017
