edtuck
I am a DIY homeowner and I am converting a portion of my den into a master bath. The vanity is going on the same wall as the vanity in the main bath, but on the other side. It seems most efficient to let these four sinks share plumbing. I was planing on using at least 2 double fixture fittings for the sinks that are back to back and then probably a double fixture fitting to bring the waste from the back to back sinks together with the ones to the right and left. I am attaching a diagram of my idea and pictures taken from another site of the two concepts I am combining. I also believe I may need to add a clean out below each of my Double fixture fittings. I am thinking I may not want to use a double fixture fitting where things combine because it just adds another vent which is not necessary. The plumbing then becomes a single square rather than a bisected square. I think I could also choose a side and have the vent come up rather than centering it between the sinks as well. All waste and vent pipes will be 2 inch. Thank you for any replies. I am in Los Angeles, County in California and must therefore adhere to their codes.
After looking at my diagram again, I realize that I did not draw the double fixture fitting correctly where the back to back sinks combine. Imagine the bottom line lower to allow for the vertical draining of the double fixture fitting. Sorry. Thanks again for any suggestions!
