plumbing and electrical
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jodenmel1, Nov 2, 2008.
  1. jodenmel1
    jodenmel1 New Member
    Nov 2, 2008
    Next to my loafing shed there is water for my horses and electrical to the barn. When I was digging in an area close by I found that the water line and electricial are within about 6" of each other. The electrical isn't even in pipe just gray 14/2. Is it ok like that?
    Jodenmel1
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    I do not know about the 6" separation or how deep things should be, but the grey wire is likely "UF" for "underground feed" and is meant to be buried without conduit. Also, it is probably actually 14-2 w/ground UF. If you might take a look at either termination point, you should be able to see it is similar to Romex but with the ground wire actually molded-in between the black and white wires rather than simply laying between them with everything sharing a single wrapper.
  4. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    Cable rated for underground looks like standard romex on the outside, except for the color, but inside there is no paper filler or voids. If you can't read the labeling you can easily tell the difference, because the cover insulation should completely fill the spaces between the wires and ground.
Similar Threads: plumbing electrical
Plumbing Forum, Professional & DIY Advice Plumbing and electrical Jan 3, 2016
Plumbing Forum, Professional & DIY Advice Is there a plumbing equivalent to Richter's "Practical Electrical Wiring" book? May 5, 2010
Plumbing Forum, Professional & DIY Advice Question - Plumbing/Electrical Nov 3, 2009
Plumbing Forum, Professional & DIY Advice Electrical/ plumbing in same stud bay Feb 8, 2008
Plumbing Forum, Professional & DIY Advice Plumbing sink with no overflow. Please help Thursday at 9:02 AM
