Plumbers putty for tub drain, or...?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pghsebring, Jun 13, 2011.
  1. pghsebring
    pghsebring DIY Member
    Oct 23, 2008
    Florida
    I have a sterling vikrell bathtub that i need to put a pvc drain on. On this forum i saw a discussion of plumbers putty vs. silicone, and it seemed plumbers putty won. However, in the blue and orange box stores around here, they only have the standard oateys plumbers putty, and on it, the directions say "do not use on plastic." The vikrell is pretty close to "plastic" as far as i can tell.
    So what would you do here?
    stuart
  2. hj
    You need "no stain" plumber's putty, although, since Vickrell is a very smooth surface, you could probably get by with NO putty at all, (especially if you only use the shower), since all it does is "keep" the water in the tub when it is filled. It does NOT prevent leaks from under the tub.
  4. pghsebring
    Oct 23, 2008
    Florida
    I can't find "no stain" around here, the box stores only have regular old oateys plumbers putty. There also is no plumbers supply shop around here. I guess i'll have to keep looking.
Similar Threads: Plumbers putty
Plumbing Forum, Professional & DIY Advice Acrylic Tubs - Silicone vs Plumbers Putty Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Silicone Vs Plumbers Putty May 6, 2016
Plumbing Forum, Professional & DIY Advice Plumbers putty on plastic Mar 19, 2012
Plumbing Forum, Professional & DIY Advice Silicone or plumbers putty? Dec 10, 2011
Plumbing Forum, Professional & DIY Advice Concern over Plumbers Putty and CPVC/Plastic Fittings Oct 19, 2010
