Plumber installed our toilet to the pump??
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tareko, Feb 3, 2008.
  1. tareko
    tareko New Member
    Feb 3, 2008
    Hi all,
    My plumber installed a new toilet and cistern.
    We were unable to flush the toilet properly because we are using a gravity fed system and the water was unable to go into the cistern.
    He has now connected the toilet pipe to the pump so when we flush, the pump comes on.
    Is this correct?
    thanks
    __________________
  2. Cass
    Cass Plumber
    Nov 12, 2005
    It is hard to say not seeing it, but generaly speaking, if it is working correctly, it is installed correctly.
    Where do you live.
  4. tareko
    tareko New Member
    Feb 3, 2008
    hi,
    im in london uk.
    so its normal for plumbers to connect the water feed to the pump for a toilet?
    thanks
  5. Cass
    Cass Plumber
    Nov 12, 2005
    While I dont know your terminogloy lets see. The pump pumps water to the toilet, the toilet needs water to operate, the toilet wasn't working because the tank (cistern)wasn't filling with water, the plumber came and hooked up the pump (water) to the toilet, now the toilet operates.
    Is your question to us
    "should the pump (water) come on when we flush the toilet"
    Do I have all this right? If I do then yes you need pressure to fill the toilet and flushing will lower the pressure and cause the pump to turn on. I have no idea what kinds of pressure settings you may have over there.
  6. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    The problem is, we just don't understand your plumbing systems. When you say the plumber hooked the toilet to 'the pump,' we don't even know what kind of pump it is or where it is. We do not use cisterns nor do our 'water cylinders' look like yours. Typically, we have either water provided by our city at about 60 lbs. or we have a well with a submersible pump, or an above-ground jet pump. These deliver somewhere in the range of 40-60 or 50 - 70 lbs. of pressure. Our water heaters are an insulated tank with either a gas burner or a set of electric elements. (There are exceptions to these things, but this is what is most common.)
    So, in order to answer your questions, we make assumptions. But we're talking past each other. We don't know what kind of pump you have, nor whether it's normal to be hooking toilets or anything else to it, other than possibly the cistern.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    In another forum you posted in I recommended a UK plumbing forum to you. You would be far more likely to find a correct answer there. Our systems are very different from yours.
Similar Threads: Plumber installed
Plumbing Forum, Professional & DIY Advice Drain Question for the experts, Local Plumber installed shower drain question. Aug 13, 2013
Plumbing Forum, Professional & DIY Advice Is this a correct install? Pic of Shower and Toilet Drain installed by local plumber. Oct 24, 2012
Plumbing Forum, Professional & DIY Advice a plumber installed this for me -- was it done properly? Jan 1, 2012
Plumbing Forum, Professional & DIY Advice Any idea what a plumber might charge for repairing a copper pipe? Sunday at 12:59 PM
Plumbing Forum, Professional & DIY Advice Happy World Plumbing Day! We Celebrate By Interviewing ... A Plumber Mar 11, 2017
