Plumb W/D
Discussion in 'Remodel Forum & Blog' started by Eric2007, Mar 6, 2007.
  1. Eric2007
    Eric2007 New Member
    Mar 6, 2007
    I'm going to be moving my W/D up to 2nd floor and using 1/2" Pex, a couple of Sharkbites couplings & Webstone fittings for the plumbing part which I found at Houseneeds.com. My question is: How do I go about extending the washing machine drain? Does it need to run straigt down to the basement or can it elbow to a long horizantal run before elbowing down to the exhisting PVC drain?
    Thanks for any help!
  2. jadnashua
    You need the proper standpipe height, and a trap. Then you can run it down almost any way you want as long as you maintain a minimum of 1/4" per foot. I think that you'd need to re-vent it nearer to the new trap.
  4. Eric2007
    Eric2007 New Member
    Mar 6, 2007
    By 1/4" per foot you mean the slope?
  5. Eric2007
    Eric2007 New Member
    Mar 6, 2007
    proper standpipe & trap???
  6. jadnashua
    The washer drain needs to be 2". There is a vertical pipe (standpipe) above a trap that you hook the washer hose to. This needs to be a specific height (don't remember now, but you can search and find it). You need a trap below that standpipe otherwise, any soap scum in that 10-15' or more of pipe will be open to the bedrooms and smell eventually. The trap isolates all that pipe run from the house.
    Yes, that 1/4" per foot is the slope. Any near horizontal lines need that slope or more.
  7. coz
    coz New Member
    Feb 27, 2007
    MA
    it can be 1 1/2 do a 30 inch standpipe TY, trap and tie the vent in the attic.
  8. jadnashua
    Today's code, as I understand it, requires 2". Using less risks overflow from today's high efficiency washers and pumps.
Similar Threads: Plumb
Remodel Forum & Blog Plumbing layout plus steam generator Dec 3, 2016
Remodel Forum & Blog Toilet plumbing in wall? Feb 18, 2016
Remodel Forum & Blog Estimate for some plumbing work. Aug 29, 2015
Remodel Forum & Blog plumbing awards Oct 28, 2014
Remodel Forum & Blog I'm lost on plumbing Apr 5, 2014
