Plug on Lamp Fixture in Cabinet only came with One Prong
Discussion in 'Electrical Forum discussion & Blog' started by Trudijane, Jun 28, 2011.
  1. Trudijane
    Trudijane New Member
    Jun 27, 2011
    San Francisco, CA
    Hi,
    I've already bought a new lamp, however, I do like the original lamp that came with the cabinet (vintage) because it's smaller and the switch is on the lamp and not on the wire of the plus.
    So I just would like to replace end of the old plus with a compatible new plug. I'd rather not do it myself, but I also don't want to pay a fortune to an electrician to just do this for me.
    The guy in the hardware store knew exactly what to do, but they are not allowed. Is there someone who can explain exactly (preferably with a diagram) what I could do to fix the old plug, step by step? How much would an electrician charge.
    Thank you.
  2. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    The guy at the hardware store could have told you what to do, but maybe he felt that you should not do it. Replacing an electrical plug on a lamp or any appliance must be done correctly so as not to create a shock hazard. the wide prong on the plug must be connected to the conductor that on the lamp end is connected to the shell (threaded part of the socket that the bulb screws into). The correct plug for the application is important too. I have never liked those plugs that the wire is pierced by, although they are the most compact and best looking ones. If done wrong, something as simple as replacing a plug can get you electrocuted or create a fire hazard. I have seen people's plug replacement jobs and was really surprised how things can go wrong. then again, Murphy said it best.
  4. hj
    I am a bit confused about what you want to do. First you say the fixture only has "one prong", which seems impossible if the light ever worked. Then you bought a new lamp, but prefer the old one which has the switch on the lamp. Then you want to replace the old plug with a "compatible new one". So the question are;
    1. Are you using the old fixture or the new one
    2. If using the old one, why do you have to change to a "compatible new plug".
    3. If you are using a new fixture, why do you have to change the "old plug".
    4. Before we could even attempt to tell you how to do it safely, and we might be reluctant to do it in any case since we cannot be sure you would do it properly, we really have to know what you are doing, why you are doing it, and what type of plug and receptacle do you have.
  5. Trudijane
    Jun 27, 2011
    San Francisco, CA
    Replacing a Plug
    Thanks for responding. Your post convinced me even more that I need a professional to do it as how you described doing it is confusing to me and I definitely don't want to create a fire hazard or get electrocuted. I'll find someone who knows what they are doing.
    As a follow-up to this question, when I installed the new lamp, it didn't go through the hole made in the back of the cabinet (even when I made it bigger) so I bent the plug prongs a little so that it would fit and then moved them back into place. I read later that this too could be dangerous if plugged in afterward! It's working fine, but is there any danger to that?
    Thanks.
  6. Trudijane
    Jun 27, 2011
    San Francisco, CA
    I already know what I'm going to do per my last answer to my post. I'm going to let a professional fix the old one so i don't need your advice anymore. Thanks, anyway.
    T
  7. hj
    Where did I ever say I'm using the old one ????
    I guess when you said this in the original posting.
Similar Threads: Plug Lamp
Electrical Forum discussion & Blog Can I plugin a 240V into a 250V receptable? Apr 19, 2016
Electrical Forum discussion & Blog How to connect L14-20 plug to normal plug ? Apr 19, 2016
Electrical Forum discussion & Blog What to do with wires when installing light switches/plugs Sep 9, 2013
Electrical Forum discussion & Blog Industrial wall fan misting on covered porch - not UL507 rated plugged into GFI Jun 10, 2011
Electrical Forum discussion & Blog Help with three duplex plugs Jun 5, 2011
