Plug Bathtub For Pressure Test
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by turkeyvulture, May 9, 2011.
  1. turkeyvulture
    turkeyvulture New Member
    Feb 5, 2009
    California
    For a DVW pressure test, how do you plug the tub? It's not practical to plug the drain and overflow, with those little cross bars in there, and I can't turn the trap to plug it caue it's connected to the overflow and the drain. Pros, what's the trick? Got an inspection in two days.
  2. hj
    Depending on WHICH drain and overflow you have, some companies have "test plugs" which fasten in using the bolt holes for the lift and turn plug and the overflow plate.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Not much help I know, but here we only pressure test the rough-in, the traps and fixtures are installed afterward.
  5. turkeyvulture
    Feb 5, 2009
    California
    Cacherchick, I thought tubs and shower pans were considered rough plumbing, since they go in before sheetrock.
  6. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    On a rough no traps installed, plug all waste arms then put under pressure plus vents
    the whole system has to be sealed,air or water test,traps installed on final test,Bowl test.
  7. SacCity
    SacCity In the Trades
    Mar 14, 2011
    Sacramento, CA
    I've always had to have the bathtubs installed for rough plumbing inspections.
    Failed one inspection for that reason!
  8. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    What the inspectors wanted to see is a PB faucet and that DWV holds.That is in this area.On the final they want to see if the trap holds.
  9. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    As with most things, California is not much like the rest of the country.
  10. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Sure you can have the tub installed,but in order to put on rough test you cannot have a trap or waste and overflow connected.
  11. PlumbPowerHouse
    PlumbPowerHouse Plumber
    Dec 10, 2009
    South Carolina
    We do a lot of new construction and when we rough in tubs, we use the test plugs that come with the waste/overflow kit. You probably should check with your local plumbing supply shop and grab a few different test plugs for your tub drain to see if you can get one to fit.
Similar Threads: Plug Bathtub
Plumbing Forum, Professional & DIY Advice Brass cleanout plug in older home Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Plugging a drain line Sep 30, 2016
Plumbing Forum, Professional & DIY Advice 3" Cleanout Plug Won't Screw On Aug 11, 2016
Plumbing Forum, Professional & DIY Advice Cannot fit piggyback plug through hole Apr 3, 2016
Plumbing Forum, Professional & DIY Advice Cleanout plug removal on cast iron help needed, 3.5" Oct 16, 2015
