Please offer advice for water heater replacement
Discussion in 'Water Heater Forum, Tanks' started by ron2368, Jul 5, 2013.
  1. ron2368
    ron2368 New Member
    Jan 6, 2011
    PA
    I have an old Rheem powervent I will replace with a BradfordW powervent, they are both 50 gal 40k btu. My house is plumbed with polybutylene joined with copper fittings.
    The old heater has PB running direct from the hot outlet. Should I run pex or use a certain length of copper pipe to get to the PB? Will the hot water degrade the Pex?
    When I join the pex or copper to the PB I see there are sharkbite press in adapters and pex/pb copper crimp ones. Is one more durable or preferred over the other? Thank you
  2. jadnashua
    From what I've read, plastic pipe should not be connected directly to a gas WH...you should have copper stubs coming out (I think it was at least 18") before converting to your preferred pipe type. Purists (well, purists would not use pex or PB) would prefer the crimp connection verses the push-on. Depending on where you live, some places require flexible pipe connected the WH (earthquake country) and others specifically prohibit it, so you need to find out what's allowed where you live as it's not always clear. The flexible corrugated copper or SS flex supply lines may simplify your install, and the end would screw onto a fitting you've attached to the plastic pipe rather than press-on or crimp.
  4. ron2368
    ron2368 New Member
    Jan 6, 2011
    PA
    For the cold water I need a connect to the ball valve shutoff, can I use pex from the heater or I can make a short length of copper to use instead. The copper seems more solid to me but not like it will get lots of use. Whats preferred, both seem the same effort wise.
    If I have to adjust a gas line( threaded iron pipe 5/8) angle and I tighten it 1/2 turn is that ok for the sealant or should I take it out and clean off/reapply sealant?
    The manual states to either glue it to the floor or use optional leg kit, I know they are serious. It must have a soild bottom, the air inlets are along the side. I have not turned it over to look at the bottom. Should I keep it off the floor with a 18x18 block? The one at my office is electric but it is up on 4 bricks. Not sure what to do, every gas heater I ever installed had legs.
  5. jadnashua
    If you have to loosen a gas connection, take it apart and reinstall the pipe dope. As I said before, in most places, they do not want plastic pipe connected directly to a gas WH, at least a natural venting flue type (this is because the temperatures can exceed the safe limits of plastic pipe). The installation instructions should detail this. Where you install the shutoff valve is personal preference - it could be in the copper or pex, should you be using that. Keep in mind that should you need an expansion tank in the system, that tank must also be installed between the heater and any shutoff to ensure it cannot become isolated from the heater. WHere I live, they require both a vacuum breaker and an expansion tank on all new WH.
Similar Threads: Please offer
Water Heater Forum, Tanks 50 gal electric help me please Jan 26, 2017
Water Heater Forum, Tanks Water Heater wiring, Please help Feb 22, 2015
Water Heater Forum, Tanks need water...help! Please.... Jun 29, 2013
Water Heater Forum, Tanks Your opinion on a used WH, please Sep 4, 2012
Water Heater Forum, Tanks Some advice please...I need a new water heater! Aug 21, 2012
