Please help - my toilets bubble when the washing machine is running
Discussion in 'Toilet Forum discussions' started by toilet_bubbles, Sep 19, 2004.
  1. toilet_bubbles
    toilet_bubbles New Member
    Sep 19, 2004
    We just bought a one-story house. So the two toilets and the washing machine are all on the same level, of course. The toilets bubble up for about 30 seconds when the washing machine is run.
    Would someone please explain to me why this is happening? I am worried that somethine is wrong with our plumbing system. Venting? Sewage? (By the way, I *have* noticed that some of our drains are a bit slow.)
    Thank you very much for any insight you can provide! :^)
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Toilet bubbles
    It sounds as though your drain is partly clogged. Get a professional to auger the drains and I think your troubles are over. Don't waste your time trying to snake it yourself, and more important, don't pour drain cleaning chemicals in to it. If you already have used chemicals, tell the plumber what you use, how much you used, and when you used it.
  4. toilet_bubbles
    Sep 19, 2004
    Thank you
    Thank you for the advice, Gary. I will call a plumber to get this work done.
    By the way, I did in fact use some drain cleaner in the shower and the sink drains. Why is this not a good thing to do?
    Thanks.
  5. e-plumber
    e-plumber DIY Senior Member
    Sep 1, 2004
    New York
    Drain Cleaners
    To pick up where Gary left off.
    It is never a good idea to use any chemical drain cleaners, they rarely if ever work to correct the problem, can actually make the stoppage worse when the chemicals loosen up build-up on the piping before the clog, can damage piping (depending on the type of chemicals used), combining certain chemicals can be lethal, and the most important reason not to use chemicals is because the plumber now has to deal with a clogged drain line filled with who knows what.
  6. RBPhilip
    RBPhilip New Member
    Sep 20, 2004
    Bubbling toilet
    I had a rental house that did this. The bubbling toilet was my warning that the sewer pipe was almost plugged again. Ignoring the warning induced a backup into the house...
    Ultimately it turned out that the pipe to the street was broken and had settled..
  7. oldhousetroubles
    oldhousetroubles New Member
    Jun 20, 2005
    what did you do when...
    what happened next? Is this something the city fixes? or a plumber? thanks!
  8. Gary Swart
    Sep 1, 2004
    Yakima WA
    The line from the house to the street is your problem whether it is clogged or broken.
  9. richv
    richv New Member
    Jun 21, 2005
    Accountant
    South Bend IN
    If you are on a septic system, it might be time to have it pumped.
    If the water level in one toilet raises when another is flushed there is blockage somewhere. :eek:
Similar Threads: Please help
Toilet Forum discussions Please help! Toilet is frustrating me! Dec 27, 2016
Toilet Forum discussions PLEASE PLEASE PLEASE HELP!!! My toliet tank apparently grew and NO LONGER FITS!! Nov 10, 2016
Toilet Forum discussions Very old American Standard Cadet Model F4049-16- need some help please Sep 25, 2016
Toilet Forum discussions Drake toilet won't shut off - troubleshooting help please? Aug 3, 2016
Toilet Forum discussions Need help w/ Kohler toilet, please! Aug 2, 2016
