Hi Steve.....!
Based on our phone conversation.... here are the items I would recommend to help improve your water quality....!
Once you know what you hardness level is.... we can figure what size Softener you will need for your home....
>>>> These items would all be installed in the order as shown below, in the main water supply line, starting
just after the well pump pressure tank......
If the correct amount of Chlorine is added to the raw water with the proper amount of contact time, this unit will help reduce/eliminate/precipitate
Bacteria, Tannins, Color, Sediments, Slimy Buildup, Odors &
Iron/Manganese that is present in your water....
This Stenner Injector is simple to adjust, so increasing or decreasing the level ofChlorine in the water is easily done. The injection point should be installed in the main water supply line immediately after the pump pressure tank.
1.) Our Stenner Injection pump with 15 gallon storage tank.... that can be located at this link on our website...
http://ohiopurewaterco.com/shop/customer/home.php?cat=420
The Injector should be installed in the main water line first, just after the pump pressure tank...
1ea
Stenner STS Series Tank System (STS15N+85MHP17110)
The Tank System includes the Stenner 15 gallon tank and the Stenner Classic
Series 85 Hi Pressure Feed Pump.
Our price: ...........................................................................$ 474.00
I recommend that you would start by adding 1 gallon of unscented Bleach (Clorox) with 14 gallons of water, in the Stenner Solution Tank, and setting the Stenner Pump on # 5. This should last about 4 weeks of constant use, with 2 – 4 people in the home.
2.) Here is a link to our website with the Well Mate Retention Tanks we market.....
http://ohiopurewaterco.com/shop/customer/home.php?cat=369
This tank will allow the Chlorine to have maximum contact time of at least 15 - 20 minutes. Treated water enters at the bottom of the tank... and exits out of the top of the tank.
There is also a "Blow Down" opening on the bottom of the retention tank, where you can install a 3/4" Ball Valve, that should be manually opened for 30 - 60 Seconds, at least every 30 days of use... to expel any Sediment that has settled to the bottom of the tank.
This tank would be installed after the point of injection
1ea
WellMate Universal Retention Tank (UT80)
80 gallon. 21" x 67". Shipped via Freight
Our price:............................................................................. $ 447.00
>>> The Chlorine residual in the water coming out of the Retention Tank should be set at about 1.0 ppm. <<<
3.) To help increase your low 6.54 pH closer to a more normal 7.0 level, I would recommend our 1.5 cu/ft Automatic Backwashing Calcite Filter, with the Fleck 5600SXT Timer control valve, and Vortech Resin Tank - (That will help reduce your backwash water by 15%).....be installed after the Retention Tank....
This Calcite filter will also remove Sediment Particles down to about 5 microns.... along with some Iron.... and should be set to automatically backwash every 5 days with 2 people in the home......and can be located at this link on our website...
http://ohiopurewater.com/shop/customer/home.php?cat=212
1ea Fleck 5600SXT Electronic Timer Calcite Filter 1.5 (10x54 resin tank with Dome Hole and Plug)
10x54 Vortech Resin Tank with 1-1/4" Dome Hole and Plug (Almond)
1.5 cu/ft of Calcite Media
5 gpm service flow rate
Selected options:
1 Inch Noryl Yoke with Noryl Bypass Valve
Our Price................................................................................ $659.00
4.) As you have a very high level of Iron in your Raw Water.... I would recommend our Fleck 2510SXT Timer Valve – 2.0 cu/ft Filox Iron Filter, w/Vortech Resin Tank (That will use about 15% less water to backwash), be installed after the Calcite Filter....
This Backwashing Filter will also help remove Sediment Particles..... while removing up to 15 ppm of Iron from your water....! I would recommend that you set the Filox Sediment/Iron Filter..... to automatically backwash every 2 days... with 2 - 4 people in the home....!
1ea Fleck 2510SXT Electronic Timer Backwash Filox Sediment/Iron Filter 2.0
12x52” Vortech Resin Tank (Almond)
2.0 cubic feet of Filox Media
12 gpm service flow rate
5 gpm backwash flow rate
Selected options:
1” Noryl Yoke with Noryl Bypass Valve
Our Price............................................................................................ $1061.00
We have all items in stock and our internet price includes Shipping to your address in the lower 48 US States.......!
Best Regards,
