Plastic Pipe Insulators / Brackets thru Studs for Copper Pipe -- When Required?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by speede541, Jun 29, 2010.
  1. speede541
    speede541 Member
    May 1, 2010
    Oakland
    I'm installing copper water lines, and I've noticed that the plumber who worked on other parts of my remodel used polyethylene "tube insulators" (as pictured below) in some instances, but not all.
    Is there a general rule of thumb when these should be used? Are they ever required?
    For instance, when running copper through a series of studs, would it be advisable to use one on each end? On every stud? Every third? Etc...
    I really can't determine any rhyme or reason or pattern to what the plumber before me did.
    For reference, here's the IPS version of the insulator I'm looking at:
    http://www.ipscorp.com/watertite/pipesupports/pipeinsulators
    [​IMG]
  2. moserro
    moserro New Member
    Jul 2, 2010
    Wisconsin
    I'm not an expert, but my understanding is those brackets are just used to limit vibrations in areas where there are fast acting valves (like near a washing machine), or where the pipe runs through studs/joists and vibration can occur. Just use your discretion. If you think the pipe has a chance of vibrating and causing unwanted noise, use the insulator.
  4. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    we use them for any penetration through studs ( especially metal studs ) to stop noise and limit abrasion to the pipe.
  5. Terry
    Aug 17, 2004
    You don't need to support copper every 16".
    You can skip studs. However many plumbers bang them in anyway.
    If the holes are all in a straight line, then the skipped insulators aren't needed.
  6. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
    A lot of plumbers don't use them at all, but I don't like those creeping pipe callbacks. I would put them in the one of the best inventions of the past 50 years catagory.
  7. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    Agree with (Wally Hays ), if you can get them in use on ever hole. :D
  8. hj
    I usually only use those is metal studs. For wood, I use the ones which have a "flange" with two screw/nail holes in them.
  9. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
    we call dem one Mickey Mouse ears
  10. hj
    that works.
  11. Terry
    Aug 17, 2004
    The more places you attach a pipe to the framing, the louder it gets.
    I don't use them on every hole for that reason. It's not to be cheap.
    It's noise prevention.
  12. speede541
    speede541 Member
    May 1, 2010
    Oakland
    Thanks, gents. So I scattered 'em around to a handful of locations where I thought made sense, and will continue with that approach. Still can't make sense out of the what/where/why my plumber did before me, but oh well.
    The screw holes seem superfluous since I have to pry these with a screwdriver to remove them, but since they're there, I guess I can burn a few more pennies driving anchors.
  13. speede541
    speede541 Member
    May 1, 2010
    Oakland
    Ah! So do you drill oversized holes through all the studs so the pipe makes zero contact, except for the holes which have an insulator?
  14. DavidTu
    DavidTu Member
    Dec 3, 2009
    Seattle, WA
    Would one use these with PEX tubing as well? Any guidelines for PEX that differs from that given above for Copper?
  15. Terry
    Aug 17, 2004
    The plastic insulations work well on PEX. The exterior dimensions for PEX can Copper are the same.
  16. DavidTu
    DavidTu Member
    Dec 3, 2009
    Seattle, WA
    So in summary, it sounds like the concensus is to use some sort of pipe insulator on ALL lines (not just fast-acting values) and to place either every stud/joist or every other. Yes?
    Now to go slightly off topic... For floor penetrations, Uponor has a 1/2" metal straight-through support. Is that to be used on ALL lines as well? What exactly does this protect against? (It being metal it seems it would not be for movement as I presume it would chafe.) Is this installed on top of the sole/bottom plate of a wall or where?
Similar Threads: Plastic Pipe
Plumbing Forum, Professional & DIY Advice Plumbing leak on plastic pipe Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Grease in plastic drain pipes - prevention Mar 2, 2016
Plumbing Forum, Professional & DIY Advice Boiling water VS plastic pipe Feb 13, 2014
Plumbing Forum, Professional & DIY Advice Question about black plastic pipe between meter and house. Jan 3, 2014
Plumbing Forum, Professional & DIY Advice Drainage through concrete for plastic drainpipe Aug 19, 2013
