Plastic bolts too tight
Discussion in 'Toilet Forum discussions' started by MichaelNJ, Dec 14, 2013.
  1. MichaelNJ
    MichaelNJ New Member
    Dec 14, 2013
    I'm trying to replace two toilet seats installed by the previous homeowner. Both are held in place with plastic bolts/winged nut but I am unable to loose them even a little. With a flat-head screwdriver from up top and pliers pinched on the nut underneath and maximum elbow grease, I've only succeeded in starting to strip one of them. Even trying to move the nut has proved fruitless.
    It feels like they are all deadbolted in. Can anyone offer some help, it would be greatly appreciated. This should be a five minute job, but it has me cursing up a storm!
  2. jadnashua
    Did the new seat come with new ones? If so, don't worry about it, either keep torqueing them until they break, or cut them off (need to be careful not to scratch the toilet, though). They could have used some thread locking compound on them, as those sometimes are hard to keep tight otherwise.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    More often than not is is easier to hack saw the seat mounts horizontally just above the bowl, using care not to touch the porcelain.
  5. hj
    Just drill down the center of the bolt with a 3/8" or slightly larger drill bit and the nut will fall off with the bottom of the bolt.
Similar Threads: Plastic bolts
Toilet Forum discussions Old Kohler Wellworth with plastic tubing for siphon jet Sep 7, 2014
Toilet Forum discussions Length of stiff but flexible plastic pipe prevents bowl scratching by metal snake Nov 22, 2013
Toilet Forum discussions Why I like plastic seats Jul 6, 2010
Toilet Forum discussions Plastic closet rings May 28, 2010
Toilet Forum discussions How to retrieve a plastic comb in the toilet May 13, 2010
