plaster of paris
Discussion in 'Toilet Forum discussions' started by wallygater, Dec 22, 2008.
  1. wallygater
    wallygater New Member
    Dec 16, 2007
    long island
    Is It a common, and or good practice, to set a toilet with plaster of paris under it? If so, how much do you use?
  2. maintenanceguy
    maintenanceguy In the Trades
    Aug 18, 2008
    Pennsylvania
    I know an old plumber that did this if a toilet rocked or wobbled.
    Code says to caulk around the bowl. I guess this is to stop sewer gasses from getting into the room. I personally think that's a bad idea because it just hides a leaking wax ring until the leak damages the floor. If you don't caulk, you'll see the leak as soon as it starts.
    I've seen toilets set in thinset or tile grout on a tile floor instead of caulk. The toilet is then permanently part of the floor. Removal usually means breaking the toilet.
    But leveling a toilet in plaster of paris has none of these problems. You can just put a dab in the four corners to stop wobble. It sets faster than grout or thinset. It's hard enough to do the job and the toilet isn't permanently stuck to the floor.
  4. gbh
    gbh New Member
    Dec 17, 2008
    Colorado
    I certainly see the wisdom in this, but I have a big con for not putting in caulk... My son. Dude is 7 and routinely leaks down the side of the toilet. Without caulk, urine will seep under the bowl and ferment. So, with this in mind, what would be recommended? Caulk, or no caulk?
  5. jadnashua
    Caulk. Shims if necessary to keep it from rocking first...
  6. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    If it's an upstairs toilet, caulking around the base will also help prevent nasty water from pouring onto the ceiling below, in case of an overflow.
  7. hj
    caulk
    The sealing is to prevent water from going under the toilet, not to keep sewer gas or leakage from coming out.
  8. wallygater
    Dec 16, 2007
    long island
    the plumber that set the toilet upstairs actually dumped plaster of Paris on the finished tile floor, then set the toilet on top of the plaster. I still had to caulk around it anyway. He said its the best way to set a toilet, and that's the old fashion way to do it. From the replies on this topic it sounds like no one ever heard of such a thing, and or never does this anymore.
  9. Cass
    Cass Plumber
    Nov 12, 2005
    Using grout would be the closest thing to plaster which I have never heard of but doesn't surprise me...One of the things that I do run into from time to time is plumbers putty used in place of a wax ring...not a good thing but from what I can tell was used by a few plumbers years back...
  10. Verdeboy
    Jun 12, 2006
    You can set the toilet in concrete, and it will be guaranteed not to wobble. But that's not a good plan either. I like to think about the next guy or gal who's gonna have to work on that toilet.
  11. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Unless you're a handyman! :p
  12. Verdeboy
    Jun 12, 2006
    Spock, explain?? :confused:
  13. Craig99
    Craig99 New Member
    Dec 18, 2008
    When I added a bathroom in Cypress, CA, Inspector would not pass toilet until it was caulked. He said it was to prevent sewer gases. I just installed a Guinevere. The Unifit makes it real simple to make sure you get a nice seal without worrying about the toilet messing it up. Good rim wash and excellent flush so far.
  14. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    I had an inspector that would not issue a CO until the entire base of the commode was caulked ... to prevent water seepage when mopping, etc.
  15. jadnashua
    If you have sewer gasses leaking from a toilet, it is because the wax seal is bad...you could cover it up with caulk around the toilet, but that wouldn't fix it...and, you might find the toilet in the room below after it rotted out the floor.
  16. maintenanceguy
    Aug 18, 2008
    Pennsylvania
    Exactly my point. In my opinion, caulking around the toilet base can hide a problem until real damage is done. I still think that the down side of caulking outweights the upside.
  17. Craig99
    Craig99 New Member
    Dec 18, 2008
    How long are wax gaskets suppose to last? Do you guys replace them every 3,5,or 10 years or just wait till you have sewage smell or see water leaking?
  18. jadnashua
    On a properly installed toilet, never.
  19. GabeS
    GabeS Remodel Contractor
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    A lot of people use the plaster of paris. I hear about it all the time but never used it myself. The toilet should not rock. The tile floor should be flat and level and then when you put the toilet it should not rock at all. If it rocks, then that means the floor is not level and flat.
    Good point about the caulking not allowing water or spilled urine under the toilet. If the toilet leaks that caulk will probably bubble up.
Similar Threads: plaster paris
Toilet Forum discussions Plaster of Paris Toilet Base -- Who Uses It? Aug 7, 2013
Toilet Forum discussions How do you remove a toilet set in plaster of paris? Sep 4, 2012
Toilet Forum discussions Mounting a Toilet: Grout, plaster, or putty? Sep 25, 2009
Toilet Forum discussions Twist and set closet flange & plastering a toilet Apr 16, 2007
Toilet Forum discussions Toilet comparison: Toto Carolina vs. Toto Supreme Nov 29, 2011
