Placing a new tub in existing 60 inch space.
Discussion in 'Shower & Bathtub Forum & Blog' started by SDS, Jul 5, 2008.
  1. SDS
    SDS New Member
    Jul 5, 2008
    Hello,
    We purchased a 60 inch Kohler alcove tub, we have an exactly 60 inch space in which to place this new beauty. How in the world do we place this tub into this tight area?
    It is standing on end now just waiting for your helpful reply. Thanks a million!
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Is that a frame dimension or the distance between finished wall surfaces?
  4. SDS
    SDS New Member
    Jul 5, 2008
    We have already removed the finished wallboard and the exposed frame measures @60 inches long by 32 inches wide. The tub is 60 x 32 x 20.
    Thanks for any suggestions.
  5. jimbo
    jimbo Plumber
    You will need some wiggle room. That often involves pulling the toilet out, and demo'ing a little more wall than you have. Also some creative stud notching.
    Try laying the tub down flat, laying on its front apron. Those moving blankets that U-haul sells are good to protect the tub. Now you have to find cubbies in stud cavities, and as I said, possibly notch some studs, to turn it so it is in final position, just still tipped on its front. Once there, just tip it into final position.
    Sometimes, you can put it vertical, put it in postition, then wiggle it down, but if all the water piping and valves are there, that usually gets in the way.
  6. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    that is a fun job
    I hope that you have removed the tub faucet,
    because you are gong to have to...
    If you can lay it down in the room then you have it easy
    because all you have to do is slide it or sit on your butt and use your legs and feet to push it into place.....
    If you have all the plumbing fixtures still in place then it gets pretty MEAN
    you have to walk it down to the opposite ind from the drain,
    then about three of you have to lay it down into place ,,,,
    usually the lip will hit a 2x4 as it goes down and then the real challenge begins.....
    we have had to cut out the 2x4s up to about 36 inches
    high before and then re-install them on the one side. later .
    it really depends on how lucky you get and how strong
    your back is...
    have fun
  7. SDS
    SDS New Member
    Jul 5, 2008
    My wife and I want to thank all of you who responded to our pleas for help. We applied everyone's advice and finally "muscled" the tub into place. It's a tight fit but it is level and waiting for the finishing touches.
    Thanks again for the timely and sage assistance.
Similar Threads: Placing existing
Shower & Bathtub Forum & Blog Replacing Bathtub Jan 6, 2017
Shower & Bathtub Forum & Blog Replacing bathtub shoe gasket Nov 17, 2016
Shower & Bathtub Forum & Blog Replacing tub valve set: which side of the wall to work from? Nov 10, 2016
Shower & Bathtub Forum & Blog Replacing shower drum trap Oct 21, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
