pitless adapter question
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by heatherw, Sep 5, 2010.
  1. heatherw
    heatherw New Member
    Sep 5, 2010
    Winchester, VA
    Hello, I am in the process of connecting the pitless adapter in my well but am having some problems. My well is 680 ft deep, so this has been a difficult process. There is a PLASTIC check valve in my Jacuzzi 2HP pump that went bad. I've replaced it with a brass check valve which seems to be holding the water in the line. I was also having a 2nd problem at the pitless adapter which was allowing air to seep into the well line and into the house. I saw a lot of corrosion and took the o ring out and cleaned it, gooped it with vaseline and put it into place again. Pushing the o ring back in was a little difficult because it would not seat properly. If you push it in place at the top it would come out a little elsewhere. While the tractor was lowering it and the pitless was being lined up it sliced the o ring and would not seat properly without slicing it. Assuming this was human error, we redid the process and have lost a 2nd o ring the same way. What am I doing wrong? Should I have put the lubricant in before placing the o ring in the groove the way I did, or is this why it is wanting to pop out. Should I put the o ring in without lubricant and then lubricate just around the outer face of the o ring? It is the correct o ring for the pitless adapter, any ideas? Thanks in advance!!
    Heather
  2. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    In all my years of pump/well service I never had to replace an O ring in a pitless. I would clean our the O ring grove the best I could, dry it and install the O ring dry into the groove. Then lubricate the face of the O ring and reinstall the slide in portion of the pitless and his should do it.
    Always keep in mind everyone is an expert at a distance. . . you are there and only you really know what's happening. A friend of mine says that a "Consultant" is a mechanic from out of town and he's pretty much right!
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    I have had several pitless units where the o-ring gets sliced everytime I set it down. I use the next size smaller o-ring. I have to stretch it over the fitting a little, which makes the o-ring smaller in diameter. This has worked me me several times.
  5. heatherw
    heatherw New Member
    Sep 5, 2010
    Winchester, VA
    Found out that the problem was the t-bar that we used to lower the part to connect to the other half of the pitless adapter was bent. Straighted out the bar and it slid in, no problems. Thanks for the advice.
    Heather
Similar Threads: pitless adapter
Pumps and Tanks Well Forum & Blog. Water is life. Pitless Adapter Question Tuesday at 8:38 AM
Pumps and Tanks Well Forum & Blog. Water is life. Pitless Adapter Fitting Question Feb 17, 2017
Pumps and Tanks Well Forum & Blog. Water is life. How to remove Pitless Adapter Support Plate Dec 19, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well, Leak at Pitless Adapter Oct 5, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pitless Adapter - Stainless or Brass? Jul 28, 2016
