Pitcher Hand Well Pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by ton, Oct 20, 2008.
  1. ton
    ton New Member
    Jul 3, 2008
    Ok couldn't get the help I need from the local store. The ideal I have is to install a pitcher pump on my sand point for the winter months. This would save me of having to transport water to the seasonal place. I am told if you leave the handle up on the pumps water will flow back into the well therefore no freezing of the main well pipe above the frost line. Is this true and will this idea work for drawing required water in the winter. I.m thinking after I draw water the first time after its installed it will freeze the next time I use it. Your help is appreciated.
Similar Threads: Pitcher Hand
Pumps and Tanks Well Forum & Blog. Water is life. Pitcher pump handle tight Dec 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Installing a Pitcher Pump and Well Point Apr 13, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Help with installing a Pitcher Pump Feb 13, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Pitcher Pump Instructions Aug 11, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Hand dug water well May 8, 2016
