Pipes Banging
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Darcy, Feb 6, 2007.
  1. Darcy
    Darcy New Member
    Jan 21, 2007
    I have 2 problems. When the kids run off the water quickly (single push/pull lever) the pipes make a thuding/loud Banging sound. Also when 1 person is in the shower, and someone else runs the water, the pipes in the shower bang violently. I have 2 showers doing this, and they are both about 16 years old. Could the shower issues be the valve's?
  2. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    What type of piping is the water supply in the house?
    Sounds like unsecured lines...
  4. kd
    kd New Member
    Dec 11, 2006
    Install water hammer units see water hammer post.
  5. chassis
    chassis Engineer
    Sep 12, 2005
    Engineer
    SE Pennsylvania
    Pipes also could be loose. I had this problem in a shower, and in the demolition/remodelling process I found that the pipes were not secured to any wood framing and were very very loose. The new piping I installed was secured to framing members and is now firmly attached.
  6. Darcy
    Darcy New Member
    Jan 21, 2007
    cooper pipes
    If it is in fact unsecured pipes. Is there anything I can do without tearing holes in the walls to secure them?
  7. jadnashua
    NO...if the pipes are flopping around, you need to secure them.
Similar Threads: Pipes Banging
Plumbing Forum, Professional & DIY Advice Delayed Constant Banging in Pipes before PRV and After Aug 23, 2016
Plumbing Forum, Professional & DIY Advice Heating not turned on during summer , banging and clanging from pipes Oct 29, 2014
Plumbing Forum, Professional & DIY Advice Banging pipes when running outdoor spigot. Darn kids.... Aug 25, 2014
Plumbing Forum, Professional & DIY Advice Banging pipes from sump pump Jun 14, 2014
Plumbing Forum, Professional & DIY Advice Banging pipes? Doesn't seem to be water hammer Sep 4, 2011
