Pipe Volume
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tel, Sep 7, 2006.
  1. tel
    tel New Member
    Sep 7, 2006
    Can anyone tell me how to work out how much water a lengh of pipe will hold. What I want to know is, how much water will it take to fill 500' of PEX pipe.
    Regards
    tel
  2. Rancher
    Rancher Guest
    Since you didn't give me the diameter of the pex pipe, you'll have to make the calculations yourself.
    Pi x R squared x lenght (500' or 6,000")
    Pi = 3.1415
    R = Radius of the pipe, i.e. half the diameter.
    So for 3/4" pex
    3.1415 x (.375 x .375) x 6,000 = 2650 cubic inches
    2650 / 144 = 18.4 cubic feet
    18.4 X 7.48 = about 138 gallons (7.48 gal per cubic foot)
    Rancher
  4. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Don't forget to subtract the pipe's wall thickness when you compute the radius. PEX complies with SDR 9, so the wall thickness is 1/9 of the diameter. For 3/4" pipe, that's .083", so making this adjustment throughout, and using 1728 cu in per cu ft (thanks, jimmym) I get about 7 gallons.
  5. tel
    tel New Member
    Sep 7, 2006
    Sorry about that.. 1/2 pex, I want to use it for underfloor hotwater heating system.
    Thanks
    tel
  6. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    OK. For 1/2" PEX, about 3 gallons per 500 feet.
  7. jimmym
    jimmym New Member
    Nov 21, 2005
    New York
    That's 1728 in^3 / 1 ft^3. Not 144.
  8. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I need to go back to 3rd grade.
    Correcting for lots of screwups, the real numbers are as edited (or as will be edited shortly) above. I think.
  9. tel
    tel New Member
    Sep 7, 2006
    Thanks guys..
    That was about what I thought.. My problem is I am thinking of having underfloor hotwater heating system installed in my family room, and the contractor is telling me I need about a 30 gal elec hotwater tank, seems alot to me.. Any thoughts?
    Cheers
    tel
  10. Rancher
    Rancher Guest
    Opps, not enuf coffee
  11. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    The problem is you're not just heating the 3, 7, 10, or however many gallons it might be. You're maintaining a flow at a desired temperature. Depending on the flow rate and temperature differential, you need a certain number of BTUs, which translates into a certain number of kVA, kwH, etc., which determines the size of the WH. There are a couple of guys here who can do these calculations off the top of their head, but they'll need more data than we have so far. The odds are your contractor has already done these calculations (ask him to explain) and determined the 30gal WH is appropriate.
  12. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Before you look at gallons, you need to consider BTUs per hour.
    How many BTUs per hour do you need?
    Then you need a heater that will deliver that many BTUs per hour.
    1 kW = 3413 BTU per our if you are heating with electricity.
    If you are looking at a gas heater, then you need to look at the rating of the heater, usually in Net BTU/hour.
  13. tel
    tel New Member
    Sep 7, 2006
    Thanks to every one that has replied to my question. it has been a great help.
    regards
    tel
  14. hj
    heater
    6 gallon, 30 gallon, or more is basically immaterial. You have to size it for the recovery, not the storage, so the energy input is what counts, not the size.
  15. BubbaBob
    BubbaBob New Member
    Oct 18, 2009
    N GA mountains
    Make it simple and economical
    I've just built a 706 sq ft yurt (google them...they are interesting) and for heat I installed radiant floor heating using a Takagi TK-Jr propane tankless heater. My floor has 700 linear feet of 1/2 pex-a in 4 zones, and the expansion tank is a 2.2 gal Watts, which is more than enough.
    Inexpensive, economical operation, efficient, trouble free. What more could one ask for?
  16. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Neat. I guess you don't live in the suburbs. :) What's it for?
  17. Gary Slusser
    Retired
    We already have 6 solar panels and 6 6volt AGM batteries BUT I'll ask for 2-3 more solar panels, 2-4 more AGM 6 volt batteries and a central vac system for my totally off grid motor home. Then I wouldn't have to run the generator at all. A yurt is immovable LIKE A HOUSE!
  18. hj
    volume
    And to mess up the original calculations, PEX i.d. is NOT 3/4". It is between 9/16 and 5/8 meaning that its volume is about 75% of copper tubing.
Similar Threads: Pipe Volume
Plumbing Forum, Professional & DIY Advice pipe volume Aug 10, 2010
Plumbing Forum, Professional & DIY Advice water pressure volume vs pipe size Aug 1, 2008
Plumbing Forum, Professional & DIY Advice Supply Line Pipe Type & New Stop Valve Sunday at 1:46 PM
Plumbing Forum, Professional & DIY Advice Sealing pipe through concrete Friday at 11:26 AM
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Feb 21, 2017
