Pipe squeal
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Bill, Sep 4, 2004.
  1. Bill
    Bill New Member
    Sep 4, 2004
    We have a 12 year old house that has developed a squeal when the water is turned off. No matter what faucet or toilet uses the water, about five seconds after the water is turned off there is a sharp squeal noise from the pipes. Any suggestions as to how to fix this?
  2. hj
    squeal
    My first thought would be a bad water softener, and the second possibility is a bad pressure reducing valve.
  4. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    lever ballcock
    Since this occurs as the pressure is building back up in the lines I would suspect you have a lever type ballcock that I would replace with a fluidmaster.
Similar Threads: Pipe squeal
Plumbing Forum, Professional & DIY Advice pipe squeal Jan 4, 2013
Plumbing Forum, Professional & DIY Advice Squealing in pipes after installing water hammer arrestors Nov 29, 2007
Plumbing Forum, Professional & DIY Advice Squealing Pipes Nov 9, 2006
Plumbing Forum, Professional & DIY Advice Remove PRV and Connect Straight Pipe Friday at 11:29 AM
Plumbing Forum, Professional & DIY Advice Washing Machine Standpipe and Sink Drain tied to one drain? Monday at 5:06 PM
