pipe replacement question...
Discussion in 'Shower & Bathtub Forum & Blog' started by Arashi, Mar 23, 2005.
  1. Arashi
    Arashi New Member
    Mar 23, 2005
    Hi, I am new here, and not at all knowlegdable about plumbing. :eek:
    That being said I have an issue with correcting a prblem cause by replacing some shower fixtures and installing a new shower surround this past weekend. The problem is that I accidentally cut a pipe and had to try and use a coupling to correct it. Well, that didn't work. It seemed to work through testing, but after a day under pressure a leak developed (after the surround was installed, closing up my access to the pipe).
    Now that the direct access is closed up, I have limited space to work with the leaky pipe. it is now all surrounded by wood framing and built-in drawer setups. Trying to resolder the coupling has resulted in more leaks, or "roaming" leaks. The space is so limited that I'm having a hard time getting enough heat to get the solder to flow around to where I can't get the torch (without setting the house ablaze).
    What I would like to do is cut the copper pipe further down the line where there is more room, and use a compression fitting that I would then screw on a flexhose (metalbraided pipe thing) to meet up with the central valve.
    This would alleviate working with a torch in close quarters and my fears about causeing major damage. My question is, would this work??
    Can I use a compression valve on my copper piping that has a flexhose threaded on the other end, that flexhose then threaded onto the main valve?
    I thank anyone ahead of time for any help you can provide, again, I know little about this sort of thing.
    -Arashi
  2. jimbo
    jimbo Plumber
    San Diego, CA
    You cannot use either a compression fitting nor any kind of flexible lines inside the walls. Sorry to be the bearer of bad news, but this will be sight unseen for 20+ years, and even a little drip can destroy the house in that time.
  4. Arashi
    Arashi New Member
    Mar 23, 2005
    Thanks Jimbo, I guess I will have to go with a more labor intensive solution.
    thanks again, I appreciate it.
Similar Threads: pipe replacement
Shower & Bathtub Forum & Blog Shower replacement, 1.5" to 2" conversion - do I need to replace vent pipe too? Sep 9, 2016
Shower & Bathtub Forum & Blog Shower Pipe Replacement Jul 26, 2005
Shower & Bathtub Forum & Blog Shower Head and Pipe replacement. Jun 18, 2005
Shower & Bathtub Forum & Blog Pipe extender stuck in tub spout Mar 17, 2017
Shower & Bathtub Forum & Blog New bathroom renovation pipe gripe Jan 15, 2017
