Pipe leaking behind shower..help!
Discussion in 'Shower & Bathtub Forum & Blog' started by Muse83, Apr 25, 2013.
  1. Muse83
    Muse83 New Member
    Apr 25, 2013
    Shreveport,La
    Last night I discovered 2 small leaks in 2 spots behind our shower. I'm definitely don't possess any strong plumbing skills and just wanted your opinion on if this is an extremely easy fix that anyone could do or should I stick with calling someone out? Thanks
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    A quick fix would be to just put together a new riser for the shower head, which would require sweating (soldering) copper.
    In the bigger picture, if you were looking for an upgrade, this would be a good time to have a new single handle anti-scald shower valve installed in place of that old valve.
    [​IMG]
  4. Muse83
    Muse83 New Member
    Apr 25, 2013
    Shreveport,La
    Thanks for the reply! It's a tub/shower combo so I don't think I could have the single valve could I? I'm lost with anything to do with plumbing so be patient with me haha. By riser you're referring to the copper pipe that goes up to the actual shower head right? Would it be as easy as just unscrewing the long copper pipe and replacing it with a new one?
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The fittings on the ends of the riser pipe are soldered on by the installer. Judging by your questions, it would be in your best interest to bring in a plumber to repair it for you.
  6. Terry
    Aug 17, 2004
    It would be a shame to bring in a plumber, and not replace the valve at the same time.
    Yes, a single handle valve works with tubs. The tub spout uses a diverter for the shower.
    [​IMG]
  7. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    It looks like a male adapter on the bottom, so that should unscrew, but the top where the shower arm threads in should be fastened in some way. You may have a complication at that end.
  8. Terry
    Aug 17, 2004
    We cut those out and go a little higher.
  9. hj
    The top is also a male adapter, but it will NOT unscrew if the elbow at the top was fastened properly.
Similar Threads: Pipe leaking
Shower & Bathtub Forum & Blog DIY'er Needs Help with Leaking Drain Pipe! Apr 1, 2013
Shower & Bathtub Forum & Blog Pipe extender stuck in tub spout Mar 17, 2017
Shower & Bathtub Forum & Blog New bathroom renovation pipe gripe Jan 15, 2017
Shower & Bathtub Forum & Blog Trying to replace shower head without pipe! Dec 12, 2016
Shower & Bathtub Forum & Blog Tub drain trip lever stuck in pipe Dec 6, 2016
