Pipe guard
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Ian Gills, Aug 18, 2008.
  1. Ian Gills
    Jul 24, 2007
    USA
    In my unfinished basement, my water pipe comes up through the slab via the meter and up a wall. I am worried that someday the pipe might get knocked by something.
    Is there some sort of pipe protector that I can buy and screw to the wall around the pipe to protect it?
  2. Master Plumber 101
    Master Plumber 101 In the Trades
    Aug 11, 2008
    Wisconsin
    You can purchase split ring hangers for what ever size is required. It has a 3/8" female thread tapping. Get an anchor,I perfer 3/8"-16 Red head drop in
    anchors. It holds solid. Someone may have a better idea but this is how I would do it. Make sure you get the hanger for the right piping that was used.
  4. Ian Gills
    Jul 24, 2007
    USA
    Thanks Master Plumber. It is currently supported very well with hangers but I would like some kind of casing to prevent the pipe from being damaged from a sideways knock. Most pipes are normally closed off in cupboards but since my basement is unfinished this particular section is exposed against the wall.
    If my mower got pushed into it, for example, it might split the pipe.
    Any ideas?
    And no I will not paint the pipe orange or buy a left-hand drive mower, in response to the wise-guys. ;)
  5. Master Plumber 101
    Aug 11, 2008
    Wisconsin
    My next response was going to be paint it orange but you took my thunder from me. I can honestly say I'm not sure, I've never had that question arise. Can you have someone prefab something out of a heavy duty sheetmetal? Or become Jesus and start the wood work.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Why not just build a wooden box around the pipe? You wouldn't have to go all the way to the ceiling if you didn't want to, just 4' or so would protect it.
  7. Ian Gills
    Jul 24, 2007
    USA
    Thanks Gary. I am just surprised that there isn't an existing device for this. What do commercial applications use?
    Toto?
    [​IMG]
  8. jadnashua
    If you put up a pole(s) anchored into the concrete around it, it would keep most things from being able to contact the pipe. Lead anchors and a threaded pipe into a floor plate would work, and could be removed if you ever did finish the basement.
  9. Terry
    Aug 17, 2004
    In Washington State, they install steel posts that attach to the concrete with four bolts.
    These are installed in garages, in front of devices with gas lines to prevent cars from hitting the gas connections.
  10. Gary Swart
    Sep 1, 2004
    Yakima WA
    I don't know of any product specifically intended for this purpose, I think it's just one of those things that are improvised to fit the particular situation. In other words, whatever works. You will want it to be stout enough to protect and removable without too much effort. Since you won't be crashing cars into it, while undoubtedly very effective, steel pillars might be a tad much in your basement. Possibly the simplest thing would be to put a bookcase or similar piece on each side.
  11. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Things like these would commonly be used in commercial applications.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    I'm starting to see a disturbing trend with your lawnmower driving abilities...
    Have you had your eyeglass prescription checked lately? Perhaps it is why you are able to overlook the defects in Cadet 3 Toilets...
  12. tjbaudio
    tjbaudio Sound and Light Suppervisor for a School District
    Dec 6, 2005
    sound and light suppervisor for a school district
    Wisconsin
    depending on how big and how far out I would use a 2x4 attached to the wall on both sides and a 1x4 cap. Maybe a hunk of 3" or 4" PVC/ABS with a slot (or just cut in 1/2) that fits over the pipe and secured with plumbers tape or just some screws. How about a 4x4 and a dado cutter in a table saw? I think it would depend on what was around. Take a walk at the local big box store and see what pops out.
    OH found this with a google image search look about 1/2 way down http://www.derbyhouse.co.uk/prodlist.asp?cat=165&scats=165
  13. zimzimma
    zimzimma New Member
    Aug 17, 2008
    The yellow posts mentioned above are called bollards in case anyone was wondering. I work in the banking equipment & construction industry and frequently install bollards to protect drive up equipment. you can get smaller bollards by searching with google.
    Jon
  14. hj
    protection
    Depending on how close the pipe is to the wall, there are half round enclosures, often used for electrical wires on telephone poles, that would encapsulate it.
  15. Ian Gills
    Jul 24, 2007
    USA
    Thank you for all of your suggestions. "Bollard" certainly turned up a few results.
    I am surprised that more residences are not equipped with more bump protection.
    Related to my other similar post, my garden faucet guard arrived yesterday. I have painted it red and now just need to attach it to the wall.
    Hasn't anyone ever turned up at a residence to see the main in the basement dented or bumped by a careless homeowner (or should I say careless plumber for not installing bump protection)?
    I'll probably chuck a couple of these on for good measure...[​IMG]
  16. hj
    questions
    1. What is a basement? Is that an attic under the house?
    2. Who is paying the plumber to install that protection?
    3. Be more careful when you throw stuff around in the basement.
  17. Ian Gills
    Jul 24, 2007
    USA
    Thanks HJ. The basement is unfinished under the single floor rambler I live in and own. It expands the whole area of the house and is 7 feet tall. The floor is concrete and when I look up I see the joists that support the floor of my living area. My furnace and water heater live in the basement. It could be finished as a living area oneday.
    I will be installing the protection since the plumbing is existing.
    The pipe just looks so vulnerable rising from the slab and going up a wall.
    It's just not cricket.
  18. Redwood
    Dec 15, 2007
    Service Plumber
    Ian sorry to hear you're living in a car... My grandfather had a Rambler...
    It had a push button transmission and the buttons for it were on the dash...
    If you took a long trip in that piece of junk you might as well have been living in it...
    I don't think I ever saw a car overheat more often than that one did.
    [​IMG]
  19. smellyfinger MP208845
    smellyfinger MP208845 New Member
    Aug 20, 2008
    How about installing some panduit.
  20. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Cut the back side out of a 5 gallon mud bucket. It can protect the faucet and give you a place to sit at the same time. :)
  21. Redwood
    Dec 15, 2007
    Service Plumber
    Maybe put some of these on your lawnmower...
    [​IMG]
Similar Threads: Pipe guard
Plumbing Forum, Professional & DIY Advice FlowGuard gold pipe breaks Oct 27, 2013
Plumbing Forum, Professional & DIY Advice Can I use Qestpex fittings with Vanguard pex pipe? Feb 9, 2008
Plumbing Forum, Professional & DIY Advice Vanguard pipe with Ipex Fittings? Oct 24, 2007
Plumbing Forum, Professional & DIY Advice Sealing pipe through concrete Yesterday at 11:26 AM
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Tuesday at 1:12 PM
