Pipe freeze protection cable
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dave1909, May 30, 2013.
  1. dave1909
    dave1909 New Member
    May 30, 2013
    Montreal
    Hello ,
    I need some advice,
    I will install a pipe freeze protection cable on my pipe.I will like to know your opinion on the best place to put the cable heat thermostat.In the installation instruction we can read" the thermostat should be placed on the coldest end of the pipe". The problem is that if I put the thermostat
    where my pipe froze last year (see the picture to know where) ... this portion of the pipe will not be heat , so this portion of the pipe will retain cold and never been heat...
    so my pipe had chance to freeze again next winter.
    I'm confused .... where is the best place to put the thermostat if you look at my plan?
    Thanks
    [​IMG]
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    The spot you have marked might be the lowest part that froze, but everything above that would have frozen before that even though it might have thawed before you began digging down to the part that was still frozen. Placing your thermostat at the frost line (the deepest spot where the ground freezes) would assure the lowest possible spot could not freeze, but freezing would actually begin above that point and work its way down...and I think that is what you are concerned about (just as I would be). So, I would place the thermostsat just above ground level (where freezing air would find it right away) and then be sure the heat tape began at the frost line and went all the way to the floor with pipe and tape all nicely wrapped with insulation.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Keep in mind that insulation alone will not keep the pipes from freezing. Insulation around the heat tape will slow the heat loss from the tape. That's why you need both heat tape and insulation.
  5. jadnashua
    Not all heat tape can be buried in insulation...read the instructions carefully, or risk either burning out the cable or burning down the trailer.
Similar Threads: Pipe freeze
Plumbing Forum, Professional & DIY Advice Running Easy Heat Freeze Free Water Heat Pipe Cable Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Protecting pipe from freeze in cold attic Feb 4, 2015
Plumbing Forum, Professional & DIY Advice Will White PVC pipe crack if water freezes inside it? Oct 14, 2012
Plumbing Forum, Professional & DIY Advice How long does it take a 1/2" copper pipe to freeze? Feb 10, 2008
Plumbing Forum, Professional & DIY Advice Pipes & Meter freeze protection question Sep 24, 2007
