I am building a new house, and I'm encountering a strange problem I did not expect to have.. It's a 2 story house with a 4" PVC drain / stack vent that runs vertically from the crawlspace all the way up through both first floor, second floor and through the roof. The first floor does not drain directly into this, but the one bathroom and washing machine do drain into it. The problem I seem to have is that this pipe seems to expand and get longer when warm or hot water is running into it.. cold water does not cause the problem, but hot water draining from the washing machine or warm water from the shower both cause this pipe to expand. I don't think it's very much, but the problem I have is that the holes in the framing and in the floors / ceilings, are all very tight and as the pipe expands, it is basically trying to lift the second floor of the house off the first floor, eventually something has to give, and the pipe creaks very loudly as it reluctantly slides though the extremely tight holes. after the pipe cools off, the same thing happens again, but now it's trying to pull the second floor down, which it also can't do, to it reluctantly slides through the tight holes creaking very loudly as it contracts... I had no idea pvc would expand in its length so much that I would have to allow it free movement through the framing. I'm trying to formulate a plan to fix this issue, but I wanted to get some input about it.. what is normally done to allow for this expansion and contraction?? I made the holes tight on purpose to have a way to support the weight of the pipe. removing this pipe would be a MASSIVE undertaking, so I'm trying to figure out how to fix it while the pipe is in place. It would be difficult to enlarge the holes just a slight amount without damaging the pipe, but I thought perhaps I could cut an extremely large opening around the pipe.. but then how do I support it's weight? I also thought perhaps I could just cut the pipe itself maybe in 2 places, and somehow install a rubber coupling... then the rubber might allow one end to do the expanding and contracting. Has anyone else ever even heard of this?? any suggestions on how to fix it? I'm wondering if it's better to maybe leave one tight hole near the bottom for support and allow all the expansion to go vertical... but would this affect the seal where it penetrates the roof?
Any help or advice would be greatly appreciated!
