Jdbs3
I'm replacing a boiler drain with a gate valve with one that has a ball valve. I will isolate the boiler by first closing ball valves on the return and supply side of the boiler (yes they will also be replaced after this boiler drain). I may or may not need to replace the nipple between the boiler and the current boiler drain.
Two questions:
- Will closing these 2 gate valves cause a vacuum such that minimal to no water will come out when I remove the old boiler drain? I hope so, so I don't need to drain the whole boiler.
- If not, then can pipe dope be used in the presence of water when I am switching out the boiler drain, and possibly nipple? It might need to be a quick change to lose minimal water from the boiler.
Thanks
Two questions:
Thanks
