Pipe Diameters and sizes?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chetwynd, Mar 23, 2006.
  1. chetwynd
    chetwynd New Member
    Jul 27, 2005
    California
    Hi, does anyone know of a good place to find the outer and inner diameters of pipe? For example I need to buy some hole saws, but for let's say 2" ABS, what is the outside diameter? As in, what size hole saw would I need? What about for cast iron?
    THANKS IN ADVANCE!
  2. jimbo
    jimbo Plumber
    Seach the internet . It is not rocket science, but you need to be aware that you can't just say ' 2" pipe '. There is schedule 40, there is SDR, DWV, ast iron regular and XH. So you will need to have an assortment of bits on hand if you will be working with all these things.
    Google is you friend!
  4. finnegan
    finnegan New Member
    Aug 16, 2005
    CT
    The best way to do it is to take a fitting over to the drill bit section and select a bit or in this case a hole saw, that works.
  5. hj
    size
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You don't want a tight fit anyway, so don't get too finite about the size.
  7. jadnashua
    You don't want it tight for several reasons...it is a bear to insert it, and as it expands and contracts, any tight spots will squeak or creak. It could wear a hole in the pipe as well over time.
Similar Threads: Pipe Diameters
Plumbing Forum, Professional & DIY Advice Supply Line Pipe Type & New Stop Valve Today at 1:46 PM
Plumbing Forum, Professional & DIY Advice Sealing pipe through concrete Friday at 11:26 AM
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Tuesday at 1:12 PM
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
Plumbing Forum, Professional & DIY Advice Dumb, probably repeat laundry standpipe question Feb 16, 2017
